Question about Kitchen Ranges
Thermador phe 36 us
How do i replace bulb
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
No power to the fan or lights. Checked the
You're saying fan (singular) and lights (plural)? Does this fan and these lights work off of one switch? If so, then it's probably a bad switch. You can check this by turning off the circuit breaker. Remove the switch from the wall, and put the two wires going to that switch together. Make sure to use a wire nut, or tape to keep these wires together without touching and grounding anything. Make sure these wires are clear of anyone or anything, and then go back and turn on the circuit breaker. If the lights and fan go back on, then it's a bad switch. This is what it sounds like. So now, you can turn the cir. brkr back off - replace the switch, and then after everything is secure and the switch is in the off position - you can turn the cir. brkr back on again. Then go back into the kitchen and turn the switch on again to reaffirm that everything is back in working order. If for some reason this doesn't work, feel free to contact me again. Good Luck!  Jim
Mar 30, 2010 | Thermador 30", 36", 42", 48", 60" Wall...
MODEL NUMBER HR7E SERIAL NUMBER 46-2000-893 DOUBLE DECK OVEN GIVEN A FAULT OF PHE.... WHAT DOES THIS MEAN?
ON START UP WHEN OVEN IS COLD IT WIL DISPLAY PHE TIL IT REACH A CERTIAN TEMP IF IT KEEP ON DISPLAYING PHE REPLACE YOUR TEMP PROBE
Jan 28, 2010 | Hobart HR7E Electric Single Oven
Where can I purchase the 120V, 40w bulb for E27 base thermador hsb wall hood light
Try Reliable Parts Co. at 1800-666-0313. You will probably also need your model number off of the unit.
Dec 16, 2009 | Thermador 30", 36" Silent Series Wall...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
The electronic touch control has fallen inside the hood this is the second time it has happened is there a plastic mounting bracket on the switch that has broken? left side of switch I can see a mounting...
Yep! This is a classic problem with the Therador PHE series hoods. Very weak design and NO help from the factory! Just the plastic housing is $82.00 bucks online. The panel is REALLY hard to access and the control boards, inside, fail regularly. The board alone costs over $200.00 bucks! These will fail to switch on the fan or change fan speeds or turn lights on and off or fan off. All of this randomly and arbitrarily so people tend to push the switch buttons too hard, causing the bracket to fail and entire panel body falling off inside. We have had ours propped up inside with two chop sticks for several years now and to get the fan to switch on or change speeds we fiddle with the chop sticks while repeatedly pushing the buttons and sooner or later it comes on. The lights rarely will come on, however. This unit is made by Bosch and they have all the same problems with NO fix except to replace ENTIRE control panel at a cost of $350.00 retail. This is truely an example of modern, fancy kitchen appliance over-engineered ripoff junk. Looks great but it makes sure that the fool who buys into the Brand name and cool design gets to pay and pay again for their naivete'.
Oct 16, 2009 | Thermador 30", 36", 42", 48", 60" Wall...
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
