Question about ACE Submersible Utility Pump 1/6 HP 115 V - No. 40003
Need a power cord - ACE Submersible Utility Pump 1/6 HP 115 V - No. 40003
I need replacement power cord
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 05, 2014 | Coby LEDTV2326 23 TV
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
Apex ld3249 what ac. Power cord do I need 10a 125v or 7a 125v
Hello
The power in cords have no specification and it is not a critical component to any device. Just buy one power cord, whicn meets your need. Get it from a reputed electronic spare part selling shops at your town. Keep the present power cord in hand as a sample, when you go for new one. Most of the present power cords will meet your need.
http://www.dataentryjobs.us/67948.html
en.wikipedia.org/wiki/Power_cord
Feb 01, 2012 | Televison & Video
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Need power cord
You can get the power cord from any electronic or computer store near you or you can also get a second hand power cord from EBAY....
Dec 24, 2009 | HP Photosmart D7460 Printer
I need a new power cord. I took out the back and
The power cord (E901 which plugs into P901) Hitachi part # for this model is EV00851 but it would not be commonly stocked since most repair shops would repair the cord. The repair would be done by either splicing a new cord on to the old one or unsoldering the old cords plug receptical (P901) and installing a new generic cord in its place - either way observe the polarity -white wire to thick blade of cord. Post back if you need more info (I may have a used cord)
Nov 23, 2009 | Televison & Video
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
Can't find the parts I need
Hey, not sure if you still need it, but there's a power cord for the PDM-2727 listed in an Ebay auction. Like you, I need the AV cord, er, at least I think that's the problem. The listing also shows an AV cord available for an extra $5 but it looks generic. Might be compatible though. I don't need the power cord or I'd ask the seller, but you might want to check it out if you still haven't found power cord/AV cable yet.
Mar 02, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Ilo power cord
Most computer power cords are the same as plasma power cords. Sylvania is made by Funai and that mnfg can be contacted for your nearest Funai rep. that supplies parts.
Feb 05, 2008 | Televison & Video
ACE Submersible Utility Pump 1/6 HP 115 V - No. 40003 Logo
94 people viewed this question
Top ACE Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you an ACE Water Dispensing and Filtration Expert? Answer questions, earn points and help others
