Question about Singer 7422
How to fix my singer sewing machine 7422?
My machine isn't sewing correctly since I had a needle breakage. I'm not sure if I have the shuttle and bobbin in the right location. Bunches up and tangle threads so badly I must cut them out and clean and replace throat plate every time and still can't getting working. HELP
  • 106 Answers
SOURCE: Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Posted on Mar 29, 2008
angie333
  • 5 Answers
SOURCE: singer sewing machine 7422 bobbin
hi im not an expert on domestic sewing machines bt it seems u maybe have to adjust the teeth on your machine. if you dont know how to do that a machine mechanic will do it for you for a small fee. hope that helped angela
Posted on Aug 21, 2008
  • 13 Answers
SOURCE: problem with singer prelude sewing machine!
Firstly make sure when you thread the machine you have the sewing foot in the up position or the thread will not sit in the tension and cause this problem. Also as it is a new machine it may have a small amount of oil from transport stopping the tension discs from separating. Try sliding the folded edge of a piece of fabric with the foot up through the tension unit it may clear the oil away.
Posted on Aug 27, 2008
  • 980 Answers
SOURCE: my singer sewing machine no. 127 vibrating shuttle
There are no adjustments at all on that model, it has to be down to the needle for some reason
Posted on Nov 02, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
Bottom thread not catching with top thread
The first thing you need to do is change needles, then check to make sure that the end of the needle is all the way up in the needle clamp, with the flat part against the BACK of the machine. The needle you're using may be bent or inserted too low, and that will cause the upper thread from not being able to catch the bottom thread.
If you do that and it still doesn't catch, your timing is off and will need to be corrected by a technician; however, it does not have to be an authorized Singer technician; it's a very common adjustment that any technician can do. I believe Sears services all machines. The most common reason for the timing to go off is by turning the hand wheel repeatedly away from you. ALWAYS turn it towards you, and ALWAYS thread your machine with the presser foot UP.
Jul 12, 2014 | Singer Advance 7422 Electronic Sewing...
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Singer sewing machine 534 Machine and bobbin are threaded - won' sew
A few things you can check are.
1. is the needle the right one for the machine?
2. is the needle properly inserted and oriented correctly for the machine?
3. Is the bobbin inserted correctly, so it unspools correctly for the machine?
If that all looks right, then take the needle plate off and watch the shuttle hook. It should be very close to the needle when the needle is at its bottom most part of the stroke. If it is well behind, your machine\'s timing is retarded. You\'ll need to take it in for adjustment.
Apr 13, 2013 | Singer Sewing Machines
My sewing machin sews but does not stick, the tread comes back out with the needle
Your sewing machine is not timed correctly (sound like it's ********) ... or your needle is not the correct size. Check to ensure the needle is correct first. If you are sure the needle is right and oriented correctly then it's definitely a timing issue
When I say "********" I'm not talking mental capacity... I mean the hook of the shuttle is delayed in approach and doesn't catch the loop made by the needle. To correct this you will really have to study how it works and discover how to correct it.
Or just go get it fixed by a pro.
Sep 17, 2012 | Singer Pixie Plus Electronic Sewing...
I have a singer advance #7422 sewing machine. The needle will not pick up the thread from thr bobbin although I know I have the bobbin in corectly. Can you help me with this?
You may have the needle in wrong. Check to be sure it's positioned correctly, The groove down the center of the needle should face the front of the machine. And be certain the needle is pushed completely up in its holder. If neither of these work, you might just double check the bobbin!
Nov 09, 2010 | SINGER 7470 Sewing Machine
Singer sewing machine jammed after sewing over straight pin
The shuttle and needle timing needs to be re-set. Also the hook needs to be inspected for damage.
Oct 14, 2009 | Singer Sewing Machines
Bobbin tension is too loose
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Dec 08, 2008 | Singer 7422
Mar 29, 2008 | Singer 7422
Singer 7422 Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
