Question about Dell Latitude D830 Notebook
How to get a dell latitude d830 out of safe mode?
  • 31 Answers
SOURCE: Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Posted on Dec 15, 2007
parrotheadpc
  • 2600 Answers
SOURCE: My Dell Latitude D830 will not boot up?
Your boot up needs to be repaired...follow the following repair and you should get booted back up. I do believe however that you are losing your hard drive, so watch it carefully and think about getting a backup for your files.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 12, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: my dell latitude d830 does not connect to a
you hold FN and tap f8, and it SHOULD switch. You can try using any external monitor to see if it works. If another monitor works, it is not the machine, but the projector. you can also check the bios to see if the vga port is enabled, or, check your video driver to ensure it is enabled.
Posted on Oct 26, 2009
  • 3940 Answers
SOURCE: keys locked on dell latitude d830
Hold the Fn Key and press Numlock
Posted on Apr 19, 2010
  • 4 Answers
SOURCE: restoring dell latitude d830 back to factory
You can get the restore Disks for really cheap at http://www.overlapsystems.com
Posted on May 06, 2010
Dell latitude d830 Keeps restarting after the DELL page loads at startup.
It could be because your hard drive is failing.
Try booting from a bootable CD. if it gets past the dell splash screen it's got to be the hard drive.
Jul 17, 2014 | Dell LATITUDE Computers & Internet
Dell latitude D830 will boot up to windows XP screen and then will freeze. reboot and comes up with gray screen. F2 during booting does nothing. What could it be?
Turn on the Laptop and as soon as you see the Dell screen click F8. Then click on Safe Mode Networking. Once you log into your account you will then go Superantispayware.com and download the portable version. Then run a complete scan. Then remove any viruses it picks up
Feb 05, 2013 | Dell Latitude D600 Notebook
What does the A Padlock mean on a Dell Latitude d830
Hello, Sounds like you either have a spybot or virus. When you power up your laptop immediately start hitting the f8 and go into the safe mode and check for viruses. You need to put malwarebytes on it and clean in safe mode. Here is website for malwarebytes.This is free and works.
Internet Security Product Downloads
May 24, 2012 | Dell Latitude D830 Laptop Computer PC...
JUST WANT TO KNOW HOW TO WATCH MY VIDEO IN MY PC.CO'Z I ALREADY SAVE IT IN MY PC.BUT STIL I CAN'T WATCH.
We focus on bringing the best replacement Dell Latitude D830 battery sales to our customers and desire our customers can buy their satisfying Dell Latitude D830 batteries, the Li-ion 4400mAh 11.1V Dell Latitude D830 battery on sales will be the perfect replacement to your original dell Latitude D830. We guarantee the dell Latitude D830 battery with a full one-year warranty from the date of purchase, 30-days money back, if the battery(s) have any quality problem! If you have any question or suggestion about this Latitude D830 Battery, please Contact Us so we can offer you the most convenient service.
May 14, 2010 | JVC Video Cameras
Dell Latitude D830 Notebook Logo
32 people viewed this question
Alun Cox
