Question about Other Locks & Locksmithing
Remove hollymade door knob dated from 1950s - Other Locks & Locksmithing
I have an M-1 Garand Springfield Armory Serial# 160714 could you tell me when it was made?
Ok Barry.... If its from the Springfield armoury you may have a problem. You see, the Korean Era Garands are VERY hard to pinpoint the exact month. Its because of record keeping.
The 1950s production must be approximated by year, barrel dates, etc.
But from what I can see it may be in the month of December.
Here is a link to a "born on" table....
M1 Garand Born on Date
Hope it helps you a bit.
Aug 03, 2017 | Optics
I648725
Since the 1950s Bulova has used a 2 digit date code, usually on the back below the serial number. The letter is the decade (L= '50s, M='60s, N=70s, etc.) and the number is the year. For example, a Bulova with a date code of M3 was made in 1963, one with N0 was made in 1970, and so on. Prior to the 1950s, it's more complicated.
Jul 18, 2014 | Bulova Accutron Watches
Bath room door knob is locked. How do I unlock it?
Remove outer knob with push pin, unscrew fromm door and remove there is a pin latch in side (looks like a loop of wire ) flip to top or bottom will matter if left or right hand door.
Feb 04, 2011 | Top Knobs Round Knob - Brushed Satin...
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Opener eye beams
call the installer and ask him to remove them as they dont work
seems only fair if they never worked properly for very long
I dont really understand what kids have to do with a door not working sorry even more so if you have don't have any kids,lol
This should be a simple fix for the installer.
Keep me updated thanks
Jul 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Locks & Locksmithing Logo
47 people viewed this question
Top Other Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Other Lock and Locksmithing Expert? Answer questions, earn points and help others
