Question about Nelson LR Rain Train Traveling Sprinkler 1865
Where can i find shorter arms?
Are there shorter arms?
    Welcome Back:
    Visited the website for 2 consecutive days.
They are a standard width.
Posted on Jun 07, 2014
My 31 day regulator wall clock keeps losing time. Can you please tell me how to fix it
if it has weights , rotating balls etc or pendulum the length of the arms on which these items are attached controls the adjustment
the longer the arm the slower the time and the shorter the arm the faster the time
Mar 23, 2016 | Home
Changing rear wiper blade on plastic covered arm?
check with an autoparts store but any I have had with rear wiper they were exactly the same just shorter
Mar 12, 2015 | 2009 Dodge Grand Caravan
How to adjust the swing arm
Hi Anonymous, adjusting the shocks does not alter the height of the back end, just stiffens or soften the ride, for lowering the ride height the usual options are:
1. Thinner less paded seat.
2. Rear shock lowering kit.
3. Shorter shocks.
4. Shorter air shocks.
5. Front fork lowering kit.
6. Low profile tires.
Good luck.
Mar 29, 2013 | 2008 Harley Davidson FXCWC Softail Rocker...
On the 3.1L engine in the 1999 Chevy Malibu, I need to install the intake and exhaust rocker arm and push roods.
The exhaust push rods are the shorter of the two, the intakes of course are longer. The rocker arms should have been keep in order removed but they are the same for intake and exhaust valves. Torque to the rocker arms to 13 foot pounds.
Sep 17, 2012 | Cars & Trucks
How do i adjust the front wiper arm
your best bet would be to put shorter wiper blades on car, if the arms are not out of adjustment. you can tell if the arms need readjusting. by watching and make sure they go all the way down and stop ok without hitting trim on windsheild bottom. hope this helps ! good-day !
May 04, 2012 | 2003 Volvo XC70
I Need The Pushrod Format For My 98 Chevy Venture.
The shorter pushrods go on the rocker arms that are closer to the intake side of the head, the longer ones go on the rocker arms closer to the exhaust side of the head. The camshaft is dead center in the engine, the further away from the cam the rocker arm is, the longer the pushrod needs to be.
Aug 24, 2011 | Chevrolet Venture Cars & Trucks
My windshield wipers collide with each other and end up crumpling up. how to fix? and will it hurt to simply put shorter wipers on?
Shorter wipers are the easy way out. With the wipers parked remove one of the arms completely off the car. Not the blades, but the whole arm. Reposition the arm so it is just above the other wiper blade and push the arm back on.
May 20, 2011 | Motorola Metra Volvo Antenna Adapter (40...
I need to know the push rod order for a 2001 Chevy malibu V6
look at the order of the rockers arm stands. the rocker arms itself. some are higher. the longer rods go to these arms. the shorter one go to the lower arms.
Jan 17, 2011 | 2001 Chevrolet Malibu
Scrunches up paper, wanta different pper
This is a possible solution as I had the same problem on a PSC 1510. You will need to rest the printer on its fron edge after closing the paper tray. With the bottom of the printer facing you you should see a small removable panel on the left hand side - it has one Torx screw in the upper left corner. Undo that screw and the panel can be removed - be careful not to dislodge the felt ink pad. Once the panel has been removed you will see a black plastic lever which pivots in a socket with one long arm extending to the right and a shorter arm extending down. Remove this arm and then reinstall it making sure that the small peg on the shorter arm sits in the long vertical slot of the black plastic slide inside the printer. Once you have done this the long arm should be close to horizontal. Replace the removable panel - making sure the felt ink pad is in place - and the problem should be solved.
I hope this helps.
chasmith
Apr 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
Nelson LR Rain Train Traveling Sprinkler 1865 Logo
67 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
