Question about Sylvania LC225SSX LCD TV
One channel has gone mute while all others work fine. This happened suddenly.
Have tried every setting I could I could find.
I have no audio on two TV channels (Disney and Nickelodeon). Is it possible to mute audio on individual channels? I am guessing this happened by mistake.
Have you checked your parental control settings? That would be about the only way I know of the to mute certain channels. But if your locked out a channels there would normally be no video either.
Dec 12, 2014 | Panasonic PV-C2060 Combo
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
I have Direct TV. occasionally we have a black square that covers most of the picture. It disappears temporairily when any remote button is hit--mute or going to another channel or back. It seems to...
Go into your closed captioning settings on your TV. The setting currently is in the "TEXT" mode, you want it in the CC mode or off. Hope that helps : )
Jul 27, 2011 | Televison & Video
Can't get sound on channel 4 only. Any ideas? The sound is fine on all other channels and there is sound on channel 4 on my other TV sets. I've tried pushing the mute on the remote to see if it was muted...
You might try resetting the TV to the default (look in the Menus for a Options or Tools menu and a command like Restore Default or Memory Recall). Then exit the menu (and save the settings). Return to the menu and rescan all channels.
I do not know if this will help in your case but it is a simple thing to try. I have a tv (a different manufacturer) that had a similar problem. When my outdoor antenna was pointing directly at transmitter, the closest station gave me no audio on one sub-channel and no video on the other. All the other stations were fine. Doing the reset and subsequent rescan resynched the audio and video for the sub-channels.
I hope this helps.
May 22, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Oct 18, 2009 | Audio Players & Recorders
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
Aug 26, 2009 | Element Electronics Televison & Video
Muted on Cerain Channels on Zenith SE2795W TV
Somewhere in it's lifetime, a user has set the 'user preference' to 'mute' while this channel was active. I don't know your specific set, but most TV's need a remote to work 'mute'.
Second hand set?
[A] check all buttons on TV for a crossed-out speaker symbol, or
[B] buy a universal remote and select pin for your set. Then,
Try these:
ZENITH - 000,001,004,023,038,058,059,064,073,121,135,136,153
Oct 11, 2017 | Panasonic DMR-EH60 DVD Recorder/HDD...
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
Sylvania LC225SSX LCD TV Logo
16 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
