Question about Maytag M3X05F2D Air Conditioner
Maytag M3X05F2D-A Air Conditioner, front lights don't turn on?
I have a Maytag M3X05F2D-A Air Conditioner and the front lights don't turn on? I just placed it in the window, does this mean that it needs to settle?
SOURCE: Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Posted on Aug 16, 2007
  • 31 Answers
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Posted on Nov 17, 2008
  • 10 Answers
the blower is not coming on chech for solutions in manual
Posted on May 31, 2009
gtmerkley
  • 190 Answers
SOURCE: I have a Maytag window air conditioner that is leaking out front
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
  • 92 Answers
SOURCE: NEED INSTRUCTION MANUAL FOR MAYTAG AIR CONDITIONER
maytags website probobly has that manual.
Posted on Jul 10, 2009
How to clean MX05F2A
Thank you so much! I had struggled with getting this cover off for 20 minutes or so. It's just like the other poster said; you have to put a flat head screwdriver into the bottom corners of the front cover and push outward to get the cover off. It takes some doing if your unit is as old as mine is, but with some work it will come off. I was afraid I was breaking the cover because it was pretty hard to remove. But it worked. Thanks!
Jul 17, 2012 | Maytag M3X05F2D Air Conditioner
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
WIRING DIAGRAM FOR CAPACITOR
The CAPACITOR is connected to one of the COILS of the MOTOR. So check on this one coil goes to the mains and other to the capacitor and the common to the mains supply.
You can refer to any link to give a description of a motor wiring.
check this out :
http://en.wikipedia.org/wiki/AC_motor#Permanent-split_capacitor_motor
Jul 22, 2011 | Maytag M3X05F2D Air Conditioner
What kind of filter do i need for this maytag model, and how can i change the filter? M3X05F2D-A thanks
Most have a washable filter... it is just inside or integrated into the front grille
heatman101
Jun 10, 2011 | Maytag M3X05F2D Air Conditioner
Can the outside area of a window ac be hosed out while it is in the window?
Hello, it is better to remove the unit from the window and place it out side, this way when you spray the water and you can be sure it does damage any components. When spraying the water dont use too much pressure.
May 30, 2011 | Maytag M3X05F2D Air Conditioner
Need to replace the top knob on maytag thru wall airconditioner model m3x05f2d
Hmmm i have a model f2a
and i'm having issues finding
that switch too. only thing i havent tried
yet is calling maytag for a replacement.(they might over charge)
Or call your local air conditioning supply house.
Jun 04, 2010 | Maytag M3X05F2B Air Conditioner
A/c unit will turn on but after being set on low cool for 5 minutes it will turn itself off. And not be able to turn on again unless I unplug it and plug it back in. But it never gets cold or stays on...
What I would do is take it to the work bench. Remove the case. Remove the cover on top of the compressor and check the compressor overload for signs of wear. Bypass it and see if the compressor stays on (testing purposes only). Do not leave it that way. Replace the overload if the ac stays going. Clean the coils.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2010 | Maytag M3X05F2D Air Conditioner
Maytag M3X05F2D Air Conditioner Logo
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
