Question about Sewing Machines
Assembly for Sears quilting frame with stand 25-48184C
Need assembly instructions for Sears quilting stand with frame model 25-48184C. HELP!
  • Sewing Machines Master
  • 1,860 Answers
Try contacting sears customer service and see if they can help you
1-800-549-4505
Posted on Feb 10, 2016
4 Suggested Answers
SOURCE: frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Posted on Feb 23, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Posted on Jun 05, 2009
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Tension
Several things to try, I have this set up and after six months I'm still trying to get some issues resolved.  First make sure the machine is treaded correctly, the Juki doesn't thread like most machines, make sure you have the bobbin going the correct way.  After the machine then it has to be in the frame which means that the fabric is most likely to tight, this is a common problem, if you are bending the bars then it is too tight.  Also, look at how the quilt is in relationship to the frame, is it level?  As you quilt and roll, you will need to adjust the frame up, the quilted part should not drag on the machine and the to be quilted part should not be below the machine.  It is a critical that the frame and the machine be even with each other, if not the machine will try to pull and won't sew correctly.  Also, another tip, after each quilt change your needle, the reason is that free motion is technically bending the needle.  Hope all this helps.
Sep 09, 2008 | Juki TL-98Q
Frame quilting with janome 1600 db
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Quilting
Oct 03, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
285 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
