Question about Samsung Cell Phones
En touch The entouch has something broken when u slide it I put a card though it and snapped could u fix it
Vivitar vivicam x014n
There should be a slide bar on the card.
remove it and switch it to the other position.
If it slides when you insert it to your camera, a little piece of tape should fix that.
One position is protected, one is writeable.
Jan 13, 2014 | Cameras
I have an hp mini and the power switch on the side is broken. Normally if you slide, it will snap back and the laptop will turn on but now it just slides back and forth and the laptop won't turn on?...
Hi There,
It sounds like you've broken the post that acts as a snap action switch to turn on your laptop. With that post broken, you will still physically be able to move the switch back and forth, however the snap action will not work and your laptop will remain off.
You can fix it yourself, it's not terribly ******* a netbook but for someone without experience it can be confusing, here is a link to a disassembly video: http://www.google.ca/url?sa=t&rct=j&q=hp%20mini%20disassembly&source=web&cd=2&sqi=2&ved=0CFsQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dq2xQUT9NbIg&ei=B6XPT47GG7Ky0QH0pumkCA&usg=AFQjCNFdTsIR3hOFdu_OfA_b3sAHpYbXxQ
A repair shop should be able to fix this issue for you in under ten minutes and under $40.
Jun 06, 2012 | HP Computers & Internet
Hi need help my quinny zapp hood has snapped of the slide hinge how can I fix this Thanks
Good Afternoon
If the hood has come apart from the hinge part itself it is not something that can be fixed, it will need to be replaced. If the Zapp is under 2 years please contact your retailer for a replacement hood under the 2 year mechanism warranty.
If it is over 2 years old or you do not have a proof of purchase please go to www.quinny.com and select the country you're in, then go to "Contact Us" to be put in touch with the customer service department in your country who will be able to advise costs and availability for a replacement hood.
Jul 18, 2011 | Quinny ZAPP Stroller
Every time i try to slide to unlock it wont slide. and if it will slide when i tried to put in my code the buttons wont work
your touch screen is broken you need to either send it in to apple to get it fixed or buy a new touch
Aug 29, 2009 | Apple iPod touch
IPod Touch, 1st gen, "slide to unlock" broken
If you jailbreak (quickpwn.com) there is an app on cydia that will change it to tap to unlock rather than slide so it should be more sensitive.
Aug 15, 2009 | Apple iPod touch
Broke off on/off button on Dell Dimension C521 unit
Call Dell sale if the computer is out of warranty or call technical support if in warranty and get the button replaced. As a fix for now use a screw driver to push the button in adn make sure you do not touch the screw driver metal part or you'll get a shock is the screw driver is touching the wire in the button. You can also short (make a direct contact of the two cables) the cables coming to the button once to get the system started but dont keep them short.
Jul 26, 2009 | Dell Dimension 2400 PC Desktop
Dismount door panel. VW Polo Net
Sounds like it is a broken window regulator. You will need to remove the door panel to fix it. Mine broke and I can actually pull the window up and it will stay until the vibrations of the freeway eventually make it slide back down again (this would be a temporary fix of course). Anyways, there are a couple screws behind the door handle I believe, and then some snaps around the edges, and some clips along the window line. You should get a Bentley's manual so you know exactly how to fix the window regular.
Jun 15, 2009 | 1999 Volkswagen Jetta
Broken Keys
turn off the laptop first then put back the keys in place then try snapping it by pushing the button it will come back
Oct 10, 2008 | Dell Inspiron 6000 Notebook
Pen writes in one spot, but image shows up 1/2 below.....
1. To calibrate the ENTouch 1000 power off the device.
2. Prior to restoring power touch the pen to the center of the screen and do not move it.
3. Power on the device. Leave pen in center of the screen and do not move it. If you move it the device will not enter calibration mode.
4. Allow device to boot. If you held the pen in place the EnTouch 1000 will enter calibration mode.
5. Follow the on screen instructions. Be very methodical and do not try to rush it...
Nov 20, 2007 | Ingenico eN-Touch 1000 Digital Pen
Dispaly on eN-Touch 1000 is getting blank
Check the power adapter, sometimes they get hot and they don't supply enough power to the pin pad. Also make sure that the power cable is not loose, twisted or broken, this can also contribute to the problem.
Oct 22, 2007 | Ingenico eN-Touch 1000 Digital Pen
Cell Phones Logo
11 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
