Question about Sport & Outdoor - Others
I need a replacement pole for my 18'x10' GoBeDry dome tent. It is onev of the long poles that form the dome roof) Who should I contact?
5 Suggested Answers
jaballou
  • 63 Answers
SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Posted on Dec 09, 2008
MNfisherman
  • 11896 Answers
SOURCE: Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
Posted on Jul 06, 2009
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
mcdugal2
  • 4 Answers
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
Posted on May 04, 2010
Instuctions for 13×9 cabin tent sleeps 6 wmt-1390 (not instant)
OWNER'S MANUAL WARNING: KEEP ALL FLAME AND HEAT
SOURCES AWAY FROM THIS TENT FABRIC.
This tent meets the flammability require-
ments of CPAI-84. The fabric may burn if left
in continuous contact with any flame source.
The application of any foreign substance to
the tent fabric may render the flame-resis-
tant properties ineffective.
DO NOT...
1. Do not pitch tent near an open flame.
2. Do not leave campfires unattended.
3. Do not allow CHILDREN or ADULTS
to use lighted candles, matches or
other flame sources in or near tents.
4. Do not use heating, lighting or
cooking equipment with open
flames in or near tents.
5. Do not use fuel burning/oxygen
consuming devices (i.e. heaters,
lanterns, or other flame sources)
inside your tent at any time.
6. Do not use other than recommended
water repellent compounds on your
tent.(See:"Seal the Seams")
7. Do not spray the tent with insecticide.
8. EXTREME CAUTION: Never use any
fuel burning/oxygen consuming
device, or any device that produces
fumes (including stoves, lanterns,
candles, hibachis, or heaters) in or
around your tent. Inhalation of fumes
may result in carbon monoxide
poisoning, injury and/or *****.
DO...
1. Always extinguish campfire before
leaving area.
2. Exercise care when using electricity
and lighting in and near tents.
3. Disassemble and store tent properly
after camping to ensure the tent's
longevity.
4. Always use a hammer/mallet when
driving stakes into the ground. CARE This recreational item is not intended for
use as a permanent structure, as fabric
will quickly degrade if exposed to UV
light. No (sun shelter, screenhouse, tent)
can withstand prolonged exposure to
sunlight. UV damage is not covered under
the limited 90 day warranty.
Structural Integrity
Although our tents and screenhouses are
constructed to rigid specifications, periods
of wind or rain soaking the ground may
loosen the stakes and cause the uprights to
sink into the ground. This will weaken the
rigidity of the overall structure. Water pock-
ets may also form in the roof if the unit is
not assembled taut, the weight of which
may cause broken frames and torn fabric
Storage
Tents/screenhouses must never be rolled
up or packed while damp, as mildew will
form within a few days. Allow tent to dry
completely before rolling and storing.
REPLACEMENT PARTS Always mention the Model number in all correspondence regarding your tent and when ordering
replacement parts. ASSEMBLY INSTRUCTIONS Lay Out the Screenhouse and Poles
Select a smooth, level site and spread out your
screenhouse.
Sort the poles by number and connect the
sections together. See diagrams below for
numbering
tep 2 - Install the Poles
Insert the ends of each of the three roof poles
into the 3-way hubs
Insert the four side roof poles into the 3-way
hubs. See Diagram 2 Insert the leg poles into the hubs to raise the
screenhouse frame. Make sure that the pole
end with the holes in the sides (
down. See Diagram 3
Secure the Screenhouse
Drape the screenhouse body over the frames.
Hook the S-Hooks
located at the bottom of the leg poles.
L
Wrap the velcro tape
screenhouse, around the poles to secure them.
When the screenhouse is in its proper location,
stake it down by driving stakes through the
four D-rings
Step 4 - Install the Guy Lines
Tie the loose end of a guy line through D-ring
Repeat for the other three guy lines.
1B
Make a loop at the end of the guy line with the
L
slider. Stake the looped end of the line out
about 3' from the base of the pole. Adjust the
slider until the line is taut
C
Sep 28, 2016 | Sport & Outdoor - Others
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
Bought a tent with no poles no instructions have a model number
CONTACT MANUFACTURER FOR REPLACEMENT POLES ..OR # AND LENGTHS/DIAMETER OF POLES AND FABRICATE YOUR OWN...PERHAPS EVEN WITH SCHEDULE 40 OR BETTER PVC
Jul 30, 2012 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I have a disney princess tent that goes over a twin bed and i lost the instructions to putting it together and i need help.
  • 1
    Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
  • 2
    Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
  • 3
    Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
  • 4
    Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
  • Apr 22, 2011 | Toys
    Swiss Gear Tent - Broken Poles SG33071F
    Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
    Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    How do u erect a lichfield challenger 5 tent ?
    Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
    Aug 06, 2009 | Sport & Outdoor - Others
    Jul 25, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    Tent
    Well, you should have Three (3) longer poles and Two (2) shorter. Two (2) of the longer poles will be the basic construction poles. They will basically make an "X" across the top of the tent making the four courners of the tent. The other longer pole with also go across the top of the tent and right through the "X" made by the other two (2). This will push out the sides and make is "dome-like".
    The two (2) shorter poles will go on either side of the enterance. These will hold up the sides of the tent to give you more volume space on the inside. Not exactly nessasary but if you want more than one or two people to fit inside, you'll need these.
    Hope I helped.
    Oct 14, 2008 | Sport & Outdoor - Others
    Sport & Outdoor - Others Logo
    32 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
