Question about Garden
Why my 2007 John Deere 777 zero turn started and ran then turned the blades on and it killed the engine I checked the wires and spark plugs all seems to be fine just won't hit and run ?
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Posted on Apr 15, 2011
  • 6468 Answers
SOURCE: I have a John Deere 757 Zero Turn and the Clutch won't engage to engage blades. I pull the switch and nothing happens. have checked safety checks
check the wires just as they go into the clutch i have had them break there and have been able to repair the wire
Posted on Aug 10, 2012
  • 6468 Answers
SOURCE: John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Posted on Sep 03, 2012
I have a John Deere z225 it will start up but when I engage it CUT off
loose or malfunctioning safety mechanism under seat OR something (twine, wire, cloth material, etc. is fouling the spindle, making it impossible to turn the blade, thus killing the engine, OR a stripped or broken wire in the wiring harness before it makes connection with the seat safety connection.
Jul 26, 2017 | John Deere Garden
I have a John Deere 820 tractor. I ran over a brick with mower blade engaged now I can't get blades to re-engage.
You probably have sheared the safety pin in your pulley drive. To change you have to take the pulley off. Try turning the pulley by hand If it turns free you did shear the pin.. Take spark plug wire off before so you do not hurt yourself. Safety first.
Apr 25, 2016 | John Deere Garden
Looking for a download for electrical wiring diagram for a John Deere LT190
LT190 - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM152795.../OMM152795_H46.html
Disconnect spark plug wire(s) or battery negative (-) cable to prevent engine from starting accidentally. ยท Always wear gloves when handling mower blades or ...
Oct 15, 2015 | John Deere Garden
Why won't my 2007 John Deere L130 turn over?
remove spark plug and see it it turn over .set Brake too
May 04, 2015 | John Deere Garden
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
John deere 110 engine cranks but no spark
Check that the ignition coil kill wire is not shorted to the frame.
Check coil to flywheel gap. A business card between coil and flywheel will set correct gap.
Coil could be bad or ignition switch is not releasing the kill wire in Run/Start positions.
Nov 03, 2013 | John Deere Garden
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
Engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
Mar 01, 2010 | John Deere &Reg Branded 27" Tractor Metal...
John deere zero turn mower
Check spark plug and ensure choke is set correctly. Choke all the way out to start, then push back in. Make sure gear selector is in neutral and blade not engaged too.
Oct 22, 2008 | Sport & Outdoor - Others
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
