Question about Samsung SyncMaster 2493HM Monitor
Quickly flashing blue light 2493hm - Samsung SyncMaster 2493HM Monitor
2 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: I have a samsung syncmaster
Try it with another PC and also check the VGA cable, if it still does not work, you will have to ope it up and do in-depth troublshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Nov 07, 2010
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Samsung monitor 2493HM wont power up I plugged it it and the blue light came on for about 5 seconds then went out and I havent been able to get it going again.
The Samsung 2493HM monitor are known to have an issue with the power supply. When the power supply fails you get the 'no power' or 'slow to show picture' problems like you are having. The board can be repaired and the monitor will be just like new again. This is what the power supply board looks like:
Here is a link to a free repair guide that will walk you through the repair.
BuddyMc
Jul 02, 2011 | Samsung SyncMaster 2493HM Monitor
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
I have a Samsung Syncmaster 2493HM monitor. The problem is it seems to work when it feels like. The monitor will stay blank when i start my computer up. The power light will flash quickly, to my...
Your power supply is going out. LCD monitors have a common issue. The heat buildup in the in the cases cause parts called capacitors to overheat and bulge. When they bulge out the don't operate properly and cause the power supply to not start up correctly or not at all. First thing check the warranty, Most Samsung units have a 3year parts and labor warranty. If it is out of warranty then repair it yourself. If you can solder then you should be able to do the repair yourself. Check out our web site at:
www.ccl-la.com We don't have your exact monitor but you should be able to look at other Samsung guide we have posted and see the parts that need to be replaced. Open your case and replace any capacitors that are bulging and you should be back going again. If you don't want to do the repair yourself we do offer a repair service for you unit, check our site for details.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | Samsung SyncMaster 2493HM Monitor
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
No picture; no operation except flashing blue lcd light.
Look at the power supply first, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 30, 2009 | Samsung SyncMaster 2493HM Monitor
Samsung le32n73bd lcd tv has blue flashing light and wont turn on, after searching the net this seems to be a common problem. Any advise
Mine has justy done the same, flashing blue light and wont turn on!!
Its only 2-3 years old.
Anyone any further comments, hopefully thisd is a quick fix.
Jul 23, 2008 | Televison & Video
Samsung SyncMaster 2493HM Monitor Logo
63 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
