Question about Zoeller Electrical Supplies
Sewage pump cycles for a second then shuts off
Why do soap suds remain in the bottom of my Kenmore, model #665.13113K701, dishwasher at the end of a cycle? I have run several cycles without soap and there still are suds remaining.
My guess being I have not physically seen it:
A.Improper install and the system is not draining properly.
B.Clogging in the drain pipe at the sink to the sewage system.
C.Failing draining pump.
D.Water softener issues.
E.Someone you have over is pranking you.
Aug 06, 2014 | Kenmore Dishwashers
Where to buy a s1101 replacement sewage pump
Where replacement tank for 1101 power flush system
Aug 03, 2014 | Star Water Systems PowerFlush Sewage...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Our sewer pump loses prime, when we manually re-prime it will pump but constantly loses prime.
pumps that continually loose prime 4 sure have an air leakage problem two places that most pumps can leak air into them are (1) input shaft seal
(2) check valve
the check valve is by far the easier of the two to replace id start with that one first some waste water pumps have two check valves on them one on suction line and one on discharge line (if over 10 feet high)
Jul 31, 2011 | Monarch Pumps BE-S75 Wastewater Pump...
Pump will not shut off even when water level is down.
the float switch is getting hung up,first try to clean off the float switch ,shkae it like a rattle you should here it move inside, if that does not work relace it
Jun 10, 2011 | Zoeller M211 Automatic Aqua-Mate...
Pump runs & stops not plugged-could a cap be bad??
This pump is designed to cycle on and off as needed to pump waste to the drain.If you are saying it is turning off and not coming back on then that is the float ball switch not operating properly or the pump has become clogged and the thermos overload has turned the unit off and it will need serviced.
Feb 08, 2011 | Little Giant 20G Cia Rfs 2 Hp 58 Gpm 208V...
I need help on which wires connect to which wires on my sewage pump in order to get power to it? hydromatic sewage pump sp50 I have three wire coming off my hydromatic sewage pump two black and one green....
its 110 v the two blacks are power and green is ground. the two blacks are reversible doesnt matter one goes to white nuetral and other to black hot. ground is ground to metal.
Apr 14, 2009 | Plumbing
Water on floor after cycle
It appears your drain has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Electrical Supplies Logo
Top Zoeller Electrical Supplies Experts
Craig Butler
Craig Butler
TEKUSER
TEKUSER
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
