Question about Sony PlayStation 2 (PS2) Console
Powering off My PS2 Will power off by itself
  • 709 Answers
Hi 256male,
  1. You posted twice for the same problem. Cleanup the internal parts of your PS2.
  2. Remove the screw covers and 8 screws.
  3. Cut the warranty seal at the seams.
  4. Lift the top cover from the rear, and pull forward, then roll it to the left. Preserve the Reset Eject ribbon.
  5. Remove the two screws on both sides of the controller port.
  6. Remove the screws to the right and left of the Power socket.
  7. Lift the guts out from the back.
  8. You should be able to see how much dust and lint buildup you have .
  9. Clean everything using a dry paint brush.
  10. Reassemble
Posted on Nov 04, 2007
I think this issue is common among PS2, fixing it might cost you more than actually picking up one that is used from eBay. if you do want to try fixing it yourself you can try looking at some homemade YouTube videos, however it's not guaranteed that your problem would be exactly the same as displayed in the videos.
Apr 01, 2015 | Sony PlayStation 2 (PS2) Console
My ps2 isn't comin powering on, it fell on d ground
ok so givew it a min to cool down rehook all the wires and sometimes they come loose at the ports so wiggle them around and see if it works
Sep 08, 2011 | Sony PlayStation 2 (PS2) Console
Dual shock 2 wire digrem
The pinout is as follows when looking into the cable like this;
1 ' * * * ' * * * ' * * * ' 9
Pin Name Description
1 DATA Data
2 CMD Command
3 +7.6V
Dualshock and Dualshock 2 uses this for powering vibro-motors. Voltage on PS2 is 7.6V, however many sites says it's 9V. But it will work on 9V too.
4 GND Ground
5 VCC Vcc
6 ATT ATT select
7 CLK Clock
8 N/C Not connected
9 ACK Acknowledge
Jan 07, 2011 | Sony PS2 Dual Shock 2 Controller...
When after powering up and I had press enter, it would say CAN NOT READ DISC.
There are THREE reasons that a Slim PS2 will not read discs. I will start from most common and end at the least common (almost rare) problem.
1. A bad laser. Lasers labor on Playstation 2 [and all other video game] consoles. They eventually fail, especially if you use your PS2 as a DVD player. You can find Slim PS2 lasers at the following website. They are pretty simple to replace:
2. There are two "lid closed" sensors on the Slim Playstation 2. They let the PS2 know that the lid is shut and it should scan for a disc. Sometimes one or both of these sensors can become broken. It doesn't really happen by itself... usually if someone drops the console, one or both of the sensors can break or become dislodged.
3. A Bad Motherboard: This is rare. We mostly see this if someone installed a mod chip into the system and it eventually fails.
Click into the following website for Do It Yourself troubleshooting to determine why your PS2's discs aren't spinning, and how to fix it.
Nov 10, 2009 | Sony PlayStation 2 Slimline Console
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
PS2 Shuts Itself Down
hmm, annoyingly this is quite a common problem on the early releases of the slimline Ps2 models. The power supply units get to hot and can cause this problem. I'd recommend getting an updated PSU unit which will be available online
Mar 23, 2009 | Sony PlayStation 2 (PS2) Console
PS2 only getting a red light - not powering on
Is the system fat or slim?
If its fat then it is the internal power supply.
a 12$ total fix from parts via ebay takes 10-15 min to take apart and re-assemble. I can help you step by step let me know.
May 26, 2008 | Sony PlayStation 2 (PS2) Console
PS2 (fatty Model) Does not power on
No! absolutely do NOT open the PS2. You will make a huge mistake especially since you dont know what to look for. Besided, if someone here tells you it is one thing, how do they know for sure? Just go with the Warranty.
Apr 19, 2008 | Sony PlayStation 2 Slimline Console
Ps2 will power off
Hi 256Male
Look at the fan in the back and see if it is running. Souns like your PS2 is overheating. Sometimes so much dust and lint build up on the fan it stops. You will merely need to clean it up on the inside.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
