Question about Dell Inspiron 530 Desktop Computer
Mosaic type screen during startup
During start up I get a dot wise disturbed green screen. When I try to start Diagnostic Tools (after F12) I get a mosaic type screen(blue, red, white small rectangles of equal size)which is almost unreadable so I am not able to see the diagnostic options and start a relevant test. One single beep is produced during the start up. The computer does not start up because of a known hard disk problem detected during the start up, but the distorted screen problem is a new one - it appears even when the HD is disconnected. Could you please advise on that. Thanks. Tim
  • 56 Answers
I agree with Matthew Slattery. After what he said fails, you can try reinstall RAM in your computer. Take them out and put them back again firmly. It is recommended that you do this only if you have done this in past. Or take professional help
Posted on Apr 16, 2015
    Novelist:
    Scholar:
  • 99 Answers
First sounds like a bad video card. Could be bad screen or connection. Hard drive sounds like it is dead.
Check you screens connection if the cord is replaceable then replace it. Pins may be bent or broken if it is the d-sub hook up if usb hdmi then may need to replace the full monitor.
Posted on Oct 10, 2014
  • 90 Answers
SOURCE: Hard drive failure in system less than 2 years old!!
You need a new hard drive and your recovery disks.  Your computer takes an IDE hard drive.
Posted on Dec 14, 2008
  • 8 Answers
SOURCE: dell dimension 8100 diagnostic lights
Green Green Green amber is a start of "POV" whatever this stands for. Dells description is "System activity subsequent to video initalization" I would start with video card replacement,
Posted on Jan 09, 2009
Dellea
  • 30 Answers
SOURCE: dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Posted on Mar 27, 2009
  • 3940 Answers
SOURCE: on startup my dell 8300 only has a black screen
If you are not getting any Video at all, No Dell SPlash screen, nothing, then I'd look at a video card as the 1st point of Failure.
If you Get a Dell Splash screen, but nothing afterward, then the hard drive is suspect
Posted on Jul 09, 2009
Need to reset password for windows 7
Do a web search for reset password windows 7 and you'll find many utilities to do that. You may have to burn the software to a CD using a different machine, insert the CD in the locked machine and run the CD. Some systems aren't set to boot from CD if it's inserted, so you may have to press F12 repeatedly during startup (or another key, usually displayed on the screen during startup) to select the CD as the boot device. Some newer systems can boot from a thumbdrive, so you could try that startup selection too, if you save the download to that device.
Dec 14, 2013 | Dell Inspiron Computers & Internet
Trying to start up in dvd rom
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. May be F10? In boot options make optical drive (CD\DVD) 1st. Save and reboot. You should get "Press any key to boot from CD".
Note: Some systems have an ad-hoc boot option during startup. Thus eliminating the need for BIOS change. Might be F12
Oct 12, 2012 | HP Pavilion dv9000z Notebook
Why do the following messages: Del:Enter Set UP and F12:Boot Menu appear on screen after the computer is turned on?
These are things that someone with a high level of computer knowledge would use. Setup is for getting into the BIOS (Basic Input Output System) and changing low level settings. The boot menu is for booting off other devices such as a CD or a flash drive instead of your hard drive. This is also used for installing windows or running utilities such as memtest.
May 12, 2011 | Computers & Internet
Hi, During startup, I inserted a USB memory stick and now my screen is all messed up. It is green during startup instead of blue, and in general there are too many green pixels. (and purple pixels too) I...
remove the memory stick then try to boot up again, if still the same try to boot up under advance boot options, pressing "F8" repeatedly on the way up of boot up (from off to on) go to safe mode then try a system restore, see if that helps
Mar 23, 2011 | Medion Computers & Internet
How to enter to boot menu
Try to press F12 during startup. You need to press F12 before windows starts to load.
Another option is press F2 during startup and change the boot device in the boot device priority section.
Done that Save and Exit setup
Mar 13, 2010 | ASUS F3Jm Notebook
During start up, screen goes grey "Startup Repair is checking system for problems.." then it searches for problems for for over 1/2 hour with no solution,
Most likely the machine is looking for drivers for devices. If you are connected the internet, it is probably searching there until it times out. If you still have your motherboard installation disk, put it in the drive and boot from there. This should install any missing drivers. Press F12 during bootup to acess boot options.
Mar 12, 2010 | Dell Inspiron 1525 Notebook
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
IBM Laptop
Try going to Safe Mode. Normally you press F8 when you start the computer. When in Safe Mode, click Start -> Run then type msconfig. On the first tab, click on Diagnostic Startup. Apply, close and reboot the computer to Normal Mode. Lockups during startup are caused by startup programs.
Please rate this if you think this is helpful.
Dec 09, 2008 | IBM ThinkPad T30 2366 Notebook
Dell Inspiron 530 Desktop Computer   Logo
124 people viewed this question
Alun Cox
