H5-02
SOURCE: sharp AR 250 with error code H5-01
SHARP
AR250
H5-01
Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
SOURCE: error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
SOURCE: H5-01 error on sharp AR-M450N
Sharp AR-450
H5
01
02
Fusing unit temperature error
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
Image Processing Unit error
01
Memory back-up battery dead
02
Laser unit problem
03
HDD defective
10
black level calibration error
11
white level calibration error
13
CCD calibration error
90
F1
00
Lost communication with the Sorter
01
Sorter registration problem
02
Paper transport motor overloaded in sorter
04
Bin position error in sorter
05
06
Shift sort motor overloaded
08
Stapler position error
08
Stapler overloaded
11
Sorter problems
14
Second shift tray jammed
15
Sorter drive problems
50
Sorter not installed properly
80
No powerin sorter
F2
00
ID pattern reading error
02
Toner add mechanism malfunction
31
32
39
Drum thermistor error
F3
12
Paper does not lift in the tray
22
F9
00
Printer board problems
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
02
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
02
U2
00
EPROM error
11
EPROM error
U4
02
Duplex not working properly
03
Duplex problems
U5
00
Communication with the ADF is lost
01
Registration sensor problem in ADF
02
Exit sensor error in ADF
03
Timing sensor problems in ADF
11
Paper feed drive overloaded in ADF
U6
01
Paper lift problem in 1'st optional tray
02
Paper lift problem in 2'nd optional tray
08
Paper feed unit without power
10
PFU paper transport motor overloaded
22
50
Paper feed unit not installed properly
51
LCT not installed properly
U7
00
Main board malfunction
U9
00
Op panel problem
90
Op panel problem
EE
EU
Low toner density in the developer
EE
EL
High toner density in the developer
FA
01
PC
Key counter not installed
