Question about GE Intertherm Nordyne 5kcp29fca283as Fan Motor 1/8 Hp
Why central air conditioner outside fan not working
Radiator cooling fan, air con & central locking not working
Search Results
    newrremedies - Range Rovers
    www.rangerovers.net/newrremedies.html
    Feb 1, 2012 - Shop Manual: To diagnose and cure problems on the 4.0/4.6 it is almost... When the air conditioning failed during a summer off-pavement expedition in the..... the security/central locking portion of the service manual describes a process .... I asked the dealer to check the radiator and the viscous fan clutch.
    Air Conditioner Fan Not Working - Repair Parts ...
    www.repairclinic.com/RepairHelp/...Air-Conditioner/...---/Air-conditione...
    Heating & Cooling ..... Most Frequent Causes for Air conditioner fan not working ... On one side, the fan blade draws in outside air over the condensing coil to ..
Jan 13, 2016 | Cars & Trucks
Ruud a/c, fan works but no cold air.
if the outside fan is running you have correct voltage. compressor capacitors could be bad.
Jan 11, 2014 | Ruud Central System Air Conditioner
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My a/c system is blowing hot air; outside fan is not engaging
First check for line voltage 240v...if thats good .check for burnt wiring at fan capacitor.if you hear the compressor humming but still no fan you may need a fan motor.. when buying your new motor make sure to match horsepower and r.p.m
Jun 22, 2009 | Weather King 10AJA3601AH Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
My central air conditioner isnt working. It's a brand new air conditioner. The fan wont click on outside.
at the contactors on the outdoor unit make sure the thermostat wires have the 24 volts for the transformer on them (make sure the thermostat wires are correctly wired.
Apr 28, 2009 | Heating & Cooling
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
GE Intertherm Nordyne 5kcp29fca283as Fan Motor 1/8 Hp Logo
29 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
