Question about AOC F22 Monitor
Osd locked - How unlock osd - AOC F22 Monitor
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
Tip
Samsung LCD monitors Lock-Unlock instructions
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
on Apr 23, 2010 | Computers & Internet
Tip
HP VS-15, 17, 19, F-1705, 1905 Lock/Unlock function
OSD Lock —The OSD can be enabled or disabled by
pressing and holding the Menu button on the front panel for
10 seconds. If the OSD is locked, the warning message
“SD Lock”displays for 10 seconds.
❏If the OSD is locked, press and hold the Menu button for
10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button
for 10 seconds to lock the OSD.
May work the same on other HP model also.
User manual: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
on Apr 01, 2010 | Televison & Video
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
On screen display is locked. Fix it by:
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
AOC F22 Monitor Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
