Question about Motorola Computers & Internet
How do I change the channel on a Motorolla router?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
We are here to resolve your issue on Motorola router technical support phone number $1-8$77-%778#89^69. For more information, click on:
https://goo.gl/yT8GxT
Posted on Apr 03, 2017
  • Official Brand Answer
  • 3,100 Answers
Contact Arris Support.
ARRIS for Consumers
mark
motorola mobility support
Posted on Jan 20, 2015
How do change channels on a belkin,92
You need to access your router IP page to change frequency channels, the default IP page address is 192.168.2.1.. Open a web browser and type that address into the url, that should take you to your routers IP page. There are many settings in there you don't want to mess with if you don't know what they mean, now scroll down to wireless settings after gaining access into your router. There you will find channel options, I'd pick channel 11 also if you have a smart phone you can download an app of the google play store called WiFi analyzer. In that app it will show you how crowded channels are around you, most are on channel 1,6.
Feb 17, 2015 | Belkin Computers & Internet
How do i change channels on my router
You change the channel in the router's wireless setting.
This does not give you a stronger signal BUT you can select a different channel so you do not get interference with other wireless routers in your area that are broadcasting on the same channel.
Oct 15, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How to change a router channel
Go into the router wireless settings to change the wireless channel.
Jun 26, 2012 | Computers & Internet
Where do I go to change router channel?
You can find the user manual for your router here:
http://www.dlink.com/products/?pid=DIR-655&tab=3
To change the channel, look on page 10 of the user manual for directions on how to access the web interface of the router.
Once you get logged-in to the router, you can then go to page 22 to change the settings for the channel. You'll want to disable "Enable Auto Channel Scan" and choose 802.11g as the "802.11 Mode". Then choose the channel you require from the "Wireless Channel" selection.
Nov 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How do I change the channel on my TRENDnet TEW-432BRP router?
To change the channel, you need to loginto the router management page and click on the WLAN tab.
You can find the channel information under the WLAN tab. Change the channel ( channel 1 , 6 , 11 ) are the non overlapping channels and mostly prefered.
Oct 31, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I have the d-link 524 that i use to connect my xp laptop via wireless connection and my vista desktop through a hard connection. What I found is that my wireless connection continually goes down and will...
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not get connection to the internet with my MOTOTOLA WN 825G
at the command prompt (dos black screen) type ipconfig /renew this should reset your local ip address for the new Bell router. Your laptop is trying to use the settings from the old router.
Sep 01, 2009 | Motorola 802.11g Wireless Notebook...
No communication with one of my motorolla T6550 radios
I believe you have a defective microphone in the bad one. Since you have a new warranty, I suggest that you use it and don't wait around.
Jul 05, 2009 | Motorola Talkabout T6550 (7 Channels)...
How do i / can I connect dsl (att / motorolla modem) to USroboti
I have been working on the same problem. I found information on the router settings on the USR website http://www.usr.com/support/8054/8054-ug/three.html but after the wizzard was run and PPoE setting was set to automatic (IP is Dynamic), it still doesn't work. I believe the modem needs to be set to bridge mode, instructions for this are on AT&T's website.
http://helpme.att.net/article.php?item=12197 Good Luck.
Nov 28, 2008 | U.S. Robotics (USR8054) Router
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
90 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
