Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Enter serial number in display - Bunn Margarita Machine Ultra 2 Slush Granita Maker
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
Jul 22, 2016 | Computers & Internet
Bizhub c252 how do you reset enter serial number
NOTE
• When Main-power was turned ON while the Serial No. was not entered (including
initial status), the message to require entering the Serial No. will be displayed.
Make sure to enter the Serial No. at setup. sound like some did not follow the set procedure. go to service mode and enter the machine serial make a mistake machine will be out of commission
Mar 09, 2012 | Konica Minolta bizhub C250 All-In-One...
Imei serial
The IMEI number is uniquethe each mobile phone. The number is printed onthe label under the battery. You can also get theIMEI number by entering this on your phone *#06# It will then display your IMEI numberand you may also get a unique global serial number. Your IMEI number should be15 digits.
Feb 19, 2011 | Cell Phones
2002 TL WONT TACK RADIO CODE
Your vehicle's audio system will disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code in the preset buttons. Because there are hundreds of number combinations possible from five digits, making the system work without knowing the exact code is nearly impossible.
You should have received a card that lists your audio system code number and serial number. It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
If you should happen to lose the card, you must obtain the code number from your dealer. To do this, you will need the system's serial number.
If your vehicle's battery is disconnected or goes dead, the audio system will disable itself. If this happens, you will see ''CODE'' in the frequency display the next time you
turn on the system. Use the preset buttons to enter the five-digit code.
The code is on the radio code card included in your owner's manual kit. When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code. You have ten tries to enter the correct code. If you are unsuccessful in ten attempts, you must then leave the system on for 1 hour before trying again.
If the code card is lost, your dealer can access your code with your radio's serial number. To access the serial number, turn the radio on. It must display ''CODE'', then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release. The serial number will appear in two sets of four digits (information obtained from Owners Manual).
Hope helps (remember to rate this).
Oct 21, 2010 | 2003 Acura 3.2TL
Knowing the date of Manufacture, version, serial number.
please enter the below number
*#92702689#
It gives the following informations:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
Jul 22, 2010 | Nokia 6020 Cellular Phone
I copy new ROM on system board - error F130 Mac address not assign - please help me how to fill serial number at mode (08-995) Thanks a lot
Hi how are you this is jack my mailing ID (jack_pak@hotmail.com)
Dear follow the procedure step by step.
[F130] Invalid MAC address
Compare the serial number of the equipment with a number displayed in 08-995. If they are different,
enter the correct serial number at 08-995.
Dear check the serial no 08-995 and simple change the correct no.
when you 08-995 pree copier show a windows on the panal
check S.No ... press C buton and enter correct S.No and press the ENTER Buton.. ( correct S.No.you can check the copier back cover)... please vote me.
Thanks
Best Regards,
Jun 10, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
B6300n Printer: Hello i have oki B6300 printer and its showing e...
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Action: Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure. Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select Step #9: The operator panel will displa Note: The Operator will now display "DC132 Set Serial NumberCompleted". Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE Step #11: The operator panel will display Exit Diagnostics Incomplete Exit Step#12: Press the down arrow button the operator panel will read ExitDiagnostics Complete Exit Step #13: Press the select button the operator panel reads Complete Exit If OK Press SEL Step #14: Press the select button the operator will read Please Reboot Printer (103-208) --Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
May 17, 2010 | OKI B6300n Printer
Need to have the serial number installed in machine.
To access the serial number from the Control Panel:
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'System Admin Tools' is selected, and then press the [Enter] button.
  3. If the System Admin Tools has been passcode protected, 'Enter Passcode' will be displayed. Enter the passcode, and then press the [Enter] button. If the passcode is unknown, or has been forgotten, contact your System Administrator.
    If the System Admin Tools has not been passcode protected, 'Passcode Protect' will be displayed. Continue with step 4.
    NOTE: If the Enter button is pressed, 'Passcode Protect (No)' will be displayed. Press the Menu / Exit button to return to the previous screen, and then continue with step 4.
  4. Press the [Left] or [Right] arrow button until 'Maintenance' is displayed, and then press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until 'Serial Number' is displayed, and then press the [Enter] button. The serial number will be displayed.
  6. If ther serial number is not diosplayed, enter it via the keypad.
Jan 09, 2009 | Xerox CopyCentre C20 Black and White...
Radio code
sometimes the previous owner might wrote it down on the owners manual but if not then you need to pull the radio out and get the serial number and call the dealer they will give you a code
May 29, 2008 | 2002 Honda Accord
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
76 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
