Question about Vehicle Parts & Accessories
What type of antifreeze does a 2001 dodge stratus use?
2.4 liter engine
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Any antifreeze is better than none. these days we use the 5 year or 100,000 mile coolant. it works just fine.
Posted on Sep 09, 2014
Where's the starter located on a 2001 dodge stratus se.
A 2001 Dodge Stratus SE has a 4 cylinder 2.4 liter engine it should be under air cleaner box bolted into engine on top of front side of transmission with red battery cable attached to it. Hope this helps
Aug 03, 2014 | Cars & Trucks
Need to replace the number 5 fuel injector on 2.7 liter 2001 dodge stratus
Why change the injector?
It failed to work completely?
It leaks down when engine is off?
Your guessing at something?
Fastest way means what?
Nov 25, 2012 | 2001 Dodge Stratus
When my 2001 dodge stratus is cold and warms up the temperature gauge goes all the up too extreme hot then eventually comes down to normal. Is this a bad thermostat?
It sounds like a possible "sticking" thermostat.
I'd maybe flush the system and replace the thermostat just to be safe.
The cost of a gallon of antifreeze, a new thermostat, and some blue silicone gasket maker is a whole lot cheaper than replacing parts of an engine that overheats and warps...
Aug 15, 2011 | 2001 Dodge Stratus
What type of antifreeze can you use for a 2001 dodge stratus
You can just go to the auto parts store and ask they will give you what you need just any general brand should work fine.
Nov 11, 2010 | 2001 Dodge Stratus
What type of coolant does my Stratus need. I lost my manual.
Any standard antifreeze coolant will work. If you live in the lower Midwest USA as I do, you can actually mix regular antifreeze 50/50 with water and you run no risk of it freezing. Detailed mixing instructions should be available on most antifreeze containers.
Best of luck.
May 24, 2010 | 2001 Dodge Stratus
Need the firing order on the plugs and cap ?? 3.0
For the 2001 Dodge Stratus 3.0L SOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
........(back).........
|...1.....3.....5...|
|...2.....4.....6...|
.......(front)
Distributor:
.....(back)
...................5
...4
........................3
.....................1
......6
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Apr 27, 2010 | 2001 Dodge Stratus
What type of anti freeze do i need to use on my 2001 dodge stratus
The standard green antifreeze works, just make sure you have it half water half antifreeze (50/50)
Mar 02, 2010 | 2001 Dodge Stratus
I have changed the timing belt on a 99 Dodge Stratus with a 2.4 liter engine. All timing marks are aligned properly according to Haynes diagram and the engine will still not start. It tries to start
check your distributor position,double
check all marks again,make sure when u line up
the crank marks at #1 cyl. at compression and cam shaft marks!!
G
May 28, 2009 | 2001 Dodge Stratus
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
