Question about AquaSource Stainless Steel Replacement Faucet FS3A0000NP
Need a manual for aquasource fs3a0000np
Need a downloadable installation for an aquasource kitchen water dispenser for my information and retention
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
Need to remove softner/soap dispenser for cleaning
I presume that your dispenser has different compartments (usually 3) which appear to open into the machine. If that's the case then try squeezing the two central walls together slightly. This should allow you to pull the dispenser drawer out. Of course if we are being slightly sarcastic, what about looking in the user manual? However if you don't have one you should be able to download one from kitchen.manualsonline.com.
Jul 24, 2015 | Washing Machines
I have a aquasource faucet and the top button is stuck
Unfortunately, Aquasource is an imported faucet by Lowe's, and parts are not easy to get. You might want to visit a Lowe's and see if they have a replacement diverter unit for this faucet. If you can get one, it should take about 10 minutes to install, then you'll be like new again.
May 08, 2014 | Plumbing
Aquasource 2 handle Kitchen Faucet with sprayer as a fourth piece
I recently installed one and the center is the "holddown" hot and cold were just the hose feeds to faucet. There was a ring in center that had two screws up to base from underneath sink (hex key). Remove center ring and wiggle whole unit up and out. Dont forget to turn off water main and drain lines beforehand. Have fun.
Mar 10, 2014 | AquaSource Stainless Steel 1-Handle...
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
Need to change water filter, need location
Your question needs more information. What brand and model of range? Are you sure the range has a water connection with a filter? Maybe you are talking about refrigerator that has an ice maker and water dispenser?
Jul 02, 2011 | Kitchen Ranges
Hi I have a Sylvania hot and cold water dispenser withe refridgerator. I don't have a manual. Can I download it somewhere
Yes you should be able to go to Sylvania.com or any other appliance web site to download manual
Oct 04, 2010 | Kitchen Appliances - Others
My son shoved a spoon into the icemaker bucket and it's jammed. Now neither the ice maker nor the water dispenser works. I have emptied the ice from the bucket and stopped it from making ice. I can see the...
My ice dispenser lever stopped working. I took the face plate off by first removing the tray, grabbing the bottom face plate and pulling straight back. I found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. I'm ordering a new bracket that holds the switches. Hope this helps.
also I found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. Bad bad design!
Instead, I replaced the pins with screws.... never coming apart again. Now how long before the Ice side breaks?!?!?!?!
I had this same problem.
Whirlpool Side-by-Side Model#: ED20DFXEB01
I removed the front panel from the water/ice dispenser - just to make sure the problem was not with any of the connections there. Just put a meter on the wires to verify current. All was good.
I pulled the refrigerator out and removed the valve assembly for the water/ice dispenser. Since the ice was working and the water was not, I simply swapped the connections on the solenoids. Sure enough, when I pressed the switch to dispense water, it came through the ice maker. Answer: bad solenoid on the water side...
I happen to live close to a commercial appliance store so I took the valve assembly (along with the model number for the fridge) over there and ordered a new one. $50 and 24hrs later, I'm good to go. In my case the part I needed was part# D7742204 (technically an Amana part but was the exact same thing) and it's a very easy part to swap out on my own.
If you are still curious as to how to remove the face plate... There are 2 small slots on the bottom of the faceplate. Pry out on those and the plate slides up and off from there.
Jun 10, 2010 | Whirlpool Refrigerators
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
AquaSource Stainless Steel Replacement Faucet FS3A0000NP Logo
311 people viewed this question
Top AquaSource Plumbing Experts
Donni Steen
Tom Chichester
Are you an AquaSource Plumbing Expert? Answer questions, earn points and help others
