The speaker that has the power button is not working anymore. Any ideas???
How do they come apart as well???? maybe a loose wire or something that can be easily fixed
Yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
