Question about KitchenAid KGRS807S Gas Kitchen Range
Oven clean was on and power was interupted , now the door lock is stuck on
  • 2326 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
CMV9
  • 594 Answers
SOURCE: oven door lock
when in the cleaning mode the door lock will engage to make sure the heat does not get out. if it will not engage make sure there is nothing blocking the lock.
Posted on Aug 15, 2008
wheelshot
  • 102 Answers
SOURCE: oven door locked
Your high limit thermal fuse has blown. Pull the range out and unplug it. Pull the back panel off and in the center of the oven you will find the thermal fuse. It will have 2 wires hooked to it on either side. This will be the problem child. If it is bad, it will show a broken circuit or no continuity. Replace this fuse if it reads bad (which it most likely will) and reinstall unit. Make sure to clean the vent in the front to insure that it is free from lint or insulation that would block or slow the airflow into the unit. This air keeps the unit from over heating during self clean.
Posted on Apr 06, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Posted on Apr 07, 2009
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
Why is the oven stuck with a "Door Locked" error?
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
May 02, 2015 | GE JKP30WMWW 27" Built-in Single Electric...
I cleaned my oven and can't get the door to unlock. It has been 12 hours since it finished cleaning. I have tried to cut the power at the electrical box and this did not work
Do a a hard reset of the control panel and locking mechanism. Unplug the cord, wait five minutes and then plug it in again. Try the door. You could also try to start another cleaning, interupt after 5 min hitting the clear/off button
Sep 10, 2011 | Kenmore 41389 Electric Double Oven
The latch on the oven will not move from the locked position. Therefore, the door will not open.
Hello there and thank you for choosing fixya
This is a fairly common problems with these ovens expecially if you have just used the self clean feature or were using it and tried to interupt the cycle.
What you will need to do is first unplug the power to the oven then wait 1 full hour with out touching it then after the hour is up plug the power back in and you may hear a click sound if not wait additional 5 min then press the cancel or the off button for the self clean feature then try to open the door.
Now if this does not work than the door lock feature is either faulty or stuck which means that you will have to remove the top of the stove and unbolt the plate that is under neath there to get to the switch to release it once it has been released check it out really good to see if any of the wires look or smell burnt or the lock itself looks worn out if so replace it ok
Hope this helps you out
Best regards Mike
Aug 15, 2011 | Amana AOCS3040 Electric Single Oven
I need to clean my double ovens, but do not have the owner's manual. I know that I simple press the Clean button, but how long do I set the timer for?
You only need to reset the time if you want a cleaning cycle other than 4 hours. The default start is press Self-Clean then Start. Otherwise, press Start, type in a time between 3 and 5 hours (Min/Max cycle length) and then press Start. Do this with the number pad, do not press the Timer button. If you wish to clean both ovens, the second one will start when the first one finishes.
The Locked door light will go off when the oven has cooled below the Lock temperature. If you interupt the cleaning cycle by pressing Clear/Off, the door will remain locked until the oven cools.
I hope this helps.
Sep 25, 2010 | GE Profile JTP56 Electric Double Oven
Did the self clean and now the oven door will not unlock
Hi
Door is not unlocking as the control has detected a problem with door latch switch or the cycle was interupted in between. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether you are able to unlock the door. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. Please post back for any further assistance...
Daniel
Aug 28, 2010 | Kenmore Kitchen Ranges
It,s always written DOOR on my lcd oven board.The oven doesn't heat.
Hi, it sounds like one of the "lock" switches for the self clean door lock assembly may be faulty, or the oven door light/monitor switch is faulty. Is the oven light "on" ? Either that or when the unit was last placed in self clean the cycle may have been interupted by a power failure or some other accidental/intentional "cancel" command. Try unplugging the unit and plugging it in again right away. The "reset" should force the oven thru a start-up cycle, it essentially makes the onboard "watchdog/monitor" in the processor to check all the switches for the proper position and makes the lock go thru a lock to unlock position. The unit may correct itself just by going thru this off-on process. Hope that helps, let me know. Good luck
Oct 01, 2009 | Ovens
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Oct 05, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error Code F1 on oven timer panel
I have the same problem as above. Is there any quicker way to get an answer from tech support. I have no stove or oven right now.
Sep 05, 2008 | Kenmore 46123 Stainless Steel Electric...
Oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Jan 26, 2008 | Whirlpool RBS305PDS Electric Single Oven
KitchenAid KGRS807S Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
