Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Electrolux refrigerator turns on and off - Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Electrolux EI28BS56IS8 REFRIGERATOR will not turn on by pushing on/off button. What could cause this.
Press And hold for three (3) seconds to turn off
the cooling system to clean the refrigerator. It
also turns off the ice maker and all dispenser
functions. The temperature display will read OFF
Do it again to turn on Download Manual PDF
APPLIANCE 911
Sep 17, 2016 | Electrolux Refrigerators
Why is the electrolux refrigerator won't hold set temperature? I set it +5 but its turning back to +18. What should i do? Not any of function mode could be set, its always turned to +18.
Hey Beke, thank you for your submission!
Based off the information you have provided your Electrolux refrigerator will not hold the temperature it is set to. When you set the temperature on the refrigerator it may take 24 hours for the temperature to stabilize. I may need your model number in order to further assist you. You can locate your model number on the inside wall of your refrigerator usually on a silver or white tag. With this information I would be able to assist you further. -Matt
Apr 09, 2016 | Electrolux Refrigerators
The power went off then turned back on but the electrolux side by side refrigerator control shows off how can I reset back on.
Good Afternoon friend, thank you for your post!
I understand that your Electrolux refrigerator is not coming on. Is it displaying any codes on the panel? Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on inside wall on the right hand side. I look forward to your response. -Matt
Sep 16, 2014 | Electrolux Refrigerators
Can I turn off the freezer but not the fridge on my electrolux french door bottom freezer refrigerator
Unfortunately, the lower frizzer is connected straight to the primary engine. It can't be turned off, unless you turn off the whole fridge. I know, it will be smart for Electrolux to allow that option at a consumer's discretion: to be able to turn the bottom fridge on/off.
Aug 09, 2014 | Electrolux Refrigerators
Motor running on Electrolux refrigerator
Does the unit sound like it is producing ice and never does? Or does it continue to run whether you have ice or not?
Jul 30, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Electrolux water dispensor won't shut off
hi.this sounds like either your valve is jammed open or micro switch on dispenser. (turn water off)good luck ali
Jul 06, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
How to turn off demo mode
How do you turn off the Demo mode on the electrolux side by side refrigerator??
Jul 09, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
13 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
