Question about Garden
How to install a height handle on a Toro Timemaster 30 inch mower ?
The handle to adjust the height on a Toro push mower broke. Have a new handle but don't know how it goes together.
  • 1619 Answers
SOURCE: i need to fix athe pull string on my toro push
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Posted on Jul 11, 2009
jgr4
  • 9 Answers
SOURCE: In need of a replacement handle
Look for replacement parts at http://www.reelin.com.
You can find some owner's manuals, with part numbers, here:
http://www.reelmowersetc.com/
Posted on Jul 14, 2009
mister_b_65
  • 74 Answers
SOURCE: toro mower recycler 22 inch will not start has
Is the plug actually sparking? To test this, first, unscrew the plug from the engine...then, with the wire attached to the plug, and with it laying on the deck, pull the engine over with the rope starter. If it doesn't spark, the plug needs to be replaced. The other possibility is that the kill switch is bad.
Posted on Dec 13, 2009
  • 18 Answers
SOURCE: murray 20 inch 4.75 push mower.trying to flood,only revs up when
01 Air filter might be filthy and restricting air flow calling for more fuel than necessary, especially if black smoke is coming from muffler. Supporting this is that you say it begins to run OK as it runs out of fuel.
Posted on Apr 20, 2010
SOURCE: Craftsman Electric Mulching Mower 37051
I have a craftsman 12 amp. 18" cut side discharge mower. I recently hit a rock and now the blade is loose. how can I tighten it. I have tried tightening the bolt that holds it underneath but can't. any ideas?
Posted on Aug 24, 2010
My Toro TimeMaster 30 in. Self Propelled Mower with Briggs & Stratton Engine hasn't been started in 3 months and won't start. Mr Need Help
Raymond. clean the spark plug and be sure the gap is .030 check to see if it has spark. if so pour a little gas in the carburetor, if it starts for a few seconds and dies. you have a fuel problem. be sure the fuel lines are good as well as fuel filter if equipped. you may even have to take the carburetor off and clean it real good.
Nov 16, 2016 | Toro Garden
Can I put a key start on a toro 20975
you could use a key as an immobilisation but without a starter motor it is impossible (i am guessing it is a pull start gas mower?)
Aug 21, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
I cannot pull the lever back on my Toro Grandstand in order to lift the blade into the height I would like. Would you know how to fix this? Thank you
Have you ever oiled all the little working parts on your mower? The adjusters also get dry and they rust up or just get dirty. You can try to oil all the areas that move on the height adjusters and see what happens.
Apr 01, 2015 | Toro Lawnmower 20099 Mower Mowers Lawn
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
