Question about Craftsman 26 Hp 54" Deck Yard Tractor
Leaking oil change port.
I changed the oil on my DGS 6500 for the first time.....what a mess!! I put the extention hose onto the drain port, but when I tried to get the oil to drain the whole plastic quick connect came off and the oil started to drain all over my garage floor!! I put it back on but now I have a slow drip. Craftsman could have put a more durable petcock type drain on these tractors!! Any Ideas on what to switch the factory assembly out with to keep it convenient, but stop the leak?? Thanks in advance for any helpful suggestions!
  • 3 more comments
  • johnlafond Jun 23, 2009
    Thanks for the reply. Unfortunately it did not address my problem....I need to find an alternative setup to replace the current one as I have put it back together and have a slow oil drip.
    Engine make is Kholer. hp is 26
  • johnlafond Jun 24, 2009
    Thanks for the advice. I appreciate it. Turns out the issue was with the steel threaded piece needed to be turned about a half turn more. That stopped the leak. Hopefully next time it will be less painful.
    I changed the rating...thanks for hanging in there and following up.
  • Baron Clime May 11, 2010
    What engine manufacturer and horsepower?
  • 376 Answers
I think you pulled too hard on the plastic part of the drain spout. Your supposed to open the cap, put the drain hose on the end, turn it to the left and pull out slightly, maybe like a 1/4 ". Sounds like you pulled the plastic spout completely off. To close it, you push it back and turn it to the right to lock it and replace the cap. Sounds like you don't have the pins on the metal part that's screwed into the oil pan lined up with the slots in the plastic spout. They work very well when used properly, but they can be pulled off.
Posted on Jun 23, 2009
  • 1 more comment
  • Dwain Pippen Jun 23, 2009
    Sorry that didn't help you. Other than removing the one you have from the oil pan and screwing in a nipple with an elbow and a plug, I don't know. Personally, I prefer the type you have for ease of use. I work on mowers every day and am always pleased to see that drain on engines when I go to drain the oil.
  • Dwain Pippen Jun 24, 2009
    Glad you found the problem. Not the first time I've seen the base a little loose, but never enough to leak. Maybe a little less enthusiasm pulling on the petcock next time. Hey, all this has to be worth more than one 'thunbs up'. lol
    Thanks for the rating. Glad you got it figured out. Dwain
I bought a Simpson 3000 psi gas pressure washer. When I changed the oil (first time) I found the oil does not drain out into the pan but spills over the right wheel. I called a Honda dealership and
Easiest thing to do is buy a pipe nipple of appropriate thread size, a female thread elbow the same thread size and a male threaded plug to match the coupling. Turn the pressure washer onto its side with the drain plug pointing up. Remove the drain plug the screw in the pipe nipple where the drain plug was. Thread on elbow to other end of the pipe nipple and then screw in plug to the open end of the elbow. Buy a nipple that gets you just past the frame of the pressure washer and point the elbow at any downward angle you need to avoid draining onto the wheel.
Jul 22, 2014 | Simpson Garden
Engine oil leak
Michael
its a oil cooler it sounds like the gasket is blown just replace it no need to drain engine but u will get oil rfunning out put some thing under to catch oil
Nov 03, 2013 | Nissan Rogue Cars & Trucks
Changing leaking transmission lines
First up have some blanking plugs handy to put on the fittings you remove the hoses from on the tranny. Will save a lot of mess and oil There may be oil to the cooler so be prepared for a bit of a mess there. Replace the hoses ensureing the nuts are tight. Run the engine and check for low oil in the tranny as the lines will take up oil. Add oil if necessary
Jan 12, 2013 | 2006 Chevrolet Trailblazer
I have Yard Machine 638 RL, Model 0V358EA, 13,5 hp. I want to change the Oil engine how many litter must put oil in the engine
The Tecumseh OV358EA 13.5hp takes one quart of oil, 32oz or 39oz with filter. Use 30W except if it is used in very cold climates. MTD makes a drain tool for around $5 that clips onto the drain plug area and allows you to direct the draining oil into a container with a lot less mess.
tom
Apr 26, 2012 | Mtd Garden
There is oil coming out through the carbs into the four rubber tubes going into what appears to be an (airbox?). Not sure what the box is for. Oil is leaking from box onto the ground through a hose that I...
air boxes usually have a hose coming out of them for just that... to drain the air box of oil or water that gets in it. it doesnt attach to anything, it's just to drain the box onto the ground instead of all over the bike.
Aug 09, 2011 | Yamaha XJ 700 X Maxim Motorcycles
How to change engine oil
Harley has changed the oil drain position on Sportsters a lot during this time period. Look for a hose that plugs onto the frame on the left side of the bike somewhere between the bottom of the battery box on down to the bottom of the frame behind the primary cover. Take the hose off and the oil drains. Change the filter as well, Add three quarts of oil. Check the level on the dip stick. The top mark on the stick is "FULL HOT" and the lower mark is ''FULL COLD" . Keep the level between the two marks and do not overfill.
Good Luck
Steve
Sep 22, 2010 | 2000 Harley Davidson XL Sportster 883
How do you check and add transmission fluid to a 2007 craftsman dgs 6500 garden tractor? also, what type fluid do I add?
You do not change the drive oil on these tractors. It is supposed to be good for the life of the mower according to sears craftsman.
Jun 26, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
I changed my oil and filter now oil is leaking
you put to much oil in. drain some off. some oil in recirculated through breather hose's going to the air filter. If u over fill more goes in then can be handled and it drips out of airfilter and onto bike. dont put in a full 3 qts just 2.6
Jul 05, 2009 | Harley Davidson FLSTC Heritage Softail...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
415 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
