Question about Nikon Coolpix P90 24x Optical Zoom Digital Camera + Flash with Grip + 8GB Memory Card + ENEL5 Batte (K4004403) Battery Case Lens Cap Flash Memory Card Case
Why do pictures taken have a black, curved area in top corners of image unless I zoom in?
  • 176 Answers
That's because the shutter is damaged and needs repair, You are seeing it in your photos when using the wide end of the Zoom.
Posted on Sep 06, 2014
What is the thin black ring in the corner of my pictures?
It sounds like a filter, or a lens without sufficient coverage of the image area. What lens are you using? Do you have one or two filters on it? Is it a zoom lens, and does it go away if you zoom out to the telephoto end (like 55 on a 18-55 lens)? It would have to be in all four corners for the preceding to be true.
also it could be a piece of dust on your image sensor or a water spot if it is in just one place
Jul 22, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
I hit something on my camera that each time I take a picture, the preview is a tiny picture in the upper left screen and there are yellow outlines around areas of the picture and in the lower right corner,...
when you are in the playback mode, you can use the zoom function (as you use it when you take a picture), this will zoom into the image you took.
the yellow frame show you where you are in the full image.
Oct 18, 2010 | Canon PowerShot SD1000 Digital Camera
I dropped my IXUS 70. Display screen has black section.
You have a bad CCD. The CCD is like film, it is what the light hits that actually convert an image to a picture. This is a repair as a rule that is more costly than what your camera may be worth.
Jul 03, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Jul 31, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Image layering thru lens, imprinting on card in top right corner as small panoramic
Wow, that is strange. Is there a reset button or procedure, like holding power and exe or some other key combo in the manual? I had a C-5050 that would boot to a picture of a girl, not the normal Olympus splash screen, couldnt figure that one out either. Good luck, let me know if you give up on it or need more help..pishta68 at hotmail.com
Aug 14, 2006 | Olympus Camedia C-8080 Wide Zoom Digital...
Telephoto images
The D-435 has a 4x seamless digital zoom. Press the zoom button with the T on it and a zoom indicator will be displayed in the upper right corner of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy,” which is normal when using the digital zoom
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Telephoto images
The D-425 camera has a 4x “seamless” digital zoom. Press the Zoom button with the “T” on it, which also has the magnifying glass icon next to it and a zoom indicator will be displayed in the upper right corner of the LCD. The “W” represents a wider area of view as you zoom out, and the “T” represents Telephoto as you are zooming in closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy”, which is normal when using the digital zoom
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Nikon Coolpix P90 24x Optical Zoom Digital Camera + Flash with Grip + 8GB Memory Card + ENEL5 Batte (K4004403) Battery Case Lens Cap Flash Memory Card Case Logo
112 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
