Question about GE Ovens
Re GE single elec wall oven # JKP06
Looking for specs on cut out sizes as need to replace old oven w/same size. we have width & height but need depth.
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
  • 116 Answers
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Posted on Aug 31, 2008
aborcass
  • 2651 Answers
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
jyackle5
  • 8197 Answers
SOURCE: installing ge profile double oven
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Posted on Jan 18, 2009
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
Whirlpool double wall oven RBD306PD26 size specifications
From what I could get from the service manual, the oven is a standard 30 inch width. The best thing to do is get a yard stick and measure length, width, and height. Take pix with a phone so you have references to show a salesperson or a tradesman if you are buying new or having upgrades done.
Sep 02, 2015 | Whirlpool Ovens
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
What size microwave oven do I need to replace a GE jkp85?
You may have to do all the work to find one! After you take complete measurements (length, width and height) you will need to go to the appliance store with many choices to match it up!
Jan 12, 2013 | GE JKP85 Electric Double Oven
I HAVE A AMANA SINGLE WALL OVEN THE ELEMENT SPARKED AT THE BACK OF THE WALL. I PURCHASED A NEWW ELEMENT AND WHENITOOK THE OLD ONE OUT THERE WAS NO WIRE TERMINALS AT THE ENDS OF THE PLUG IN END OF THE...
when it burnt off it fell somewhere between the oven chamber and the back panel.once finding it,its just a matter of splicing a new wire terminal end and attaching it to the element. The problem lies in thats its a built in wall oven and may be needed to be removed from the cabinet to find and repair this wire. Depending how tight it fits into the cabinet it may not come out easily and even break the wood around the cabinet. which of course you could face in pulling it out to replace it with a new oven. ONe thing to keep in mind is that all wall ovens are slightly different in size and the replacement oven needs to be pretty close to the size of existing one or the cabinet will need to cut or filled in so their wont be a gap left when new one is smaller leaving a gap in cabinet up to 2 inches on either top or side walls
Aug 13, 2011 | Amana Ovens
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
Hi We need to replace wall oven model 755T what size wound it be so we can buy new one Thanks Tracy
The best way to determine the size wall oven that will fit is to partially pull out the existing one and measure the cut out of the cabinet it will fit into
Jul 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
What oven is the same size as zanussi zbf760
This is a standard single slot in oven.The sizes are below.
580mm Height / 560mm Width / 550mm Depth.Check with your local store.
Hope this helps.
May 17, 2010 | Zanussi ZBF360 Electric Single Oven
Can I use a similar bake element if I can't find the exact match
Yes, I would say you could use a different shaped element.
Apr 28, 2009 | GE Ovens
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
