Question about Garmin GPS
On my nuvi 660, the screen suddenly stoped functioning. I have followed the instruction on page 4 of the manual, disconnected the external power, oressed the reset button, reconneted the power and it did not turn back on and start to operate. On pressing the ON button, it restarted and lasts about 10 seconds and goes black again. Help Fred
    President:
  • 1,383 Answers
Conect your gpd device to computer with usb cable then check it working.
Also remove battery from it for some time then refix it then check.
Also try another battery.
Posted on Jun 23, 2009
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
Shuts off
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Mar 10, 2008 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 does not start
Have you tried resetting it?
  1. Disconnect from the external power source.
  2. Flip up the GPS antenna.
  3. Press the Reset button.
  4. Connect it to the power source. The unit should turn on.
Mar 05, 2008 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 turns on but displays "loading maps"
The problem is that the nuvi 660 gps receiver is jammed and needs to be reformatted.
What you have to do is to disconnect the gps, and connect it to a computer, then format it.
After formatting it, you download the self extracting archive files for your nuvi on to your hard drive, then connect your nuvi to a free USB port on your PC interface cable and allow your nuvi to initialize and enter USB mode, Unzip the files by running the downloaded executable files, then follow the instruction provided by the launched update application on your PC.
Then install it back in your car and turn it on, it will work once again.
Take care and good luck
i hope this helps?
Dec 05, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
How do i reset the 650? The touch screen isn"t responding
First you need to disconnect it from external power, then flip up the antenna to see the reset button. Press the reset button. Then reconnect it to external power, it should turn on automatically and work normally.
Aug 22, 2010 | Garmin Nuvi 660 GPS Receiver
Gps garmin nuvi 660
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - how do I get FM Transmitter firmware
I believe in your location it comes as an option. transmitter is an optional module. You can browse the user manual at following link (PDF file) http://www8.garmin.com/manuals/1262_OwnersManual.pdf
You can see at 35th page, simple instructions have been given for FM transmitter settings.
If it doesn't work please contact to the Manufacturer. I couldn't find Garmin's Ireland number. However you may call UK number +44-870-8501242. Or simple you call your reseller.
Good Luck
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Dec 10, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
46 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
