Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Where is a briggs and stratton model 191707 ignition wiring diagram ?
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
bbreton
  • 437 Answers
SOURCE: need an ignition wiring diagram for a craftsman 14
Go to www.searspartsdirect.com. put in your model number, from under the seat and it will bring up parts list and diagrams for you.
Good day.
Posted on Oct 23, 2009
rwvanlue
  • 486 Answers
SOURCE: Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
rycgl
  • 1545 Answers
SOURCE: i have a 13hp briggs and stratton model # 28m707
Go to www.searspartsdirect.com . Enter your model number, get the owners manual download and inside there will be a page with the wiring schematic for it .Good luck!
Posted on Aug 23, 2010
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Wiring diagram for a briggs & stratton model 313777
Go to Partstree.com and put in the model number. You will find some nice diagrams there.
Mar 07, 2015 | Briggs & Stratton Garden
Why don't I get spark on my briggs and stratton 3.75 model 98902
Did you check the ignition shutoff wire? Make sure it isn't grounding. It is a common Briggs problem. Take the wire off of the switch contact and check for spark again.
Aug 19, 2014 | Garden
Briggs & strattion ignition wire diagram
Check out Google and you should be able to down load a PDF Manual that will show you every thing you need to know.
Oct 02, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
