Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Is there a reset button for the temperature? - KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
Sep 03, 2013 | 2007 Honda Accord Sedan
Where is the reset button on a ED25SM Whirlpool refrigerator
refrigerators do not have a dedicated reset button, but you can, however, reset your refrigerator in the event of a technical problem.
resetting the main unit
  • 1 Turn the refrigerator's temperature control switch to "Off."
  • 2 Unplug the power cord.
  • 3 Plug the power cord back into the wall.
  • 4 Turn the control knob to adjust it to the temperature you want. leave cord unplugged for about 30 seconds. hope this helps ! good-day !
Dec 03, 2011 | Whirlpool Refrigerators
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
My Canon MP270 printer shows the following error 5200 P08
P08 (Print head temperature rise error) : 6. P08 (Print head temperature rise error): thermalprint head temperature exceeds a threshold.
Replace the new cartridge print head and / or change a new logic board.
Jan 12, 2011 | Office Equipment & Supplies
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FA error code on screen Tomy Walkabout Platinum monitor
Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
Regards,
M
Feb 21, 2010 | Tomy Freestyle Baby Carrier
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Electric hot water heater keeps throwing reset button
You most likely need to replace your thermostat. If your thermostat isn't cutting the supply to the element at the preset temperature, as it is meant to, the unit will keep on heating until the over-temperature cut-out operates. This is what the "reset button" is resetting. You should get an electrician or qualified service bloke to replace it so you dont go hurting yourself.
Mar 03, 2009 | Water Heaters
Cannot reset the temperature on my freezer
What is the manufacturer of your freezer?
Jun 26, 2017 | Freezers
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
