Question about Dell Latitude D810 Notebook
Why dell latitude d810 laptop screen black works on external monitor?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
U might have to go back to the control panel under display look on your left and click on connect o a projector and choose a option on how you want to see your screen
Posted on Sep 29, 2014
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 31, 2009
  • 3940 Answers
SOURCE: I Can't turn on my Dell Latitude D810 Laptop
From your description, it sounds like a motherboard failure. Generally about $100 on Ebay.
Posted on Nov 26, 2009
  • 561 Answers
SOURCE: very dark display screen almost black,dell latitude d810
Hi
Thank you for your query
Please try the following key combination
fn + Up Arrow
fn + Right arrow
If the above fail then it will be the inverter of the screen which will need to be replaced, please book the laptop into a reputable PC shop for replair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Posted on Feb 22, 2010
bob_computer
  • 3153 Answers
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Mar 15, 2010
When i start the computer the screen is black, and an external monitor will not work. what is wrong?
Major failure in the motherboard - the onboard video chip has failed. The only way to fix that is to replace the motherboard - a visit to a repair shop is mandatory.
Jul 25, 2011 | Dell Latitude D810 Notebook
VERTICAL LINES ON MONITOR
The Dell LatitudeD630 has a 15 pin VGA port that can connect to an external monitor located
on the back of the laptop.
Jul 23, 2011 | Dell Latitude D810 Notebook
When I turn my Dell Latitude D810 on the screen lights up just a second then goes black, then the Windows logo lights up just a second then goes black. I hear the windows music at start up and I hear it...
I would try taking the battery out and unplug it from the mains then hold the start button down for about 30 seconds then try again if no good try reseating the memory and if there is 2 sticks of memory try taking one out in turn and trying the other slot, or try starting it in safe mode (could be by continously pressing F8 on start up
Dec 01, 2017 | Dell Latitude D810 Notebook
WHAT FUNCTION ADDS A MONITOR FOR DELL D810
I assume you mean you want to connect an external monitor or data projector to your laptop. If so please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r5798263-connecting_external_monitor_or_data
Oct 02, 2010 | Dell Latitude D810 Notebook
Dell d810. replaced screen now its black.
Check the power inverter, they are a ten dollar part that starts the lcd like a ballast in a light fixture. That will usually be the culprit, it can be found usually on most laptops, near the frame that holds the lcd together, on the bottom. Take out the part and replace it. It just plugs in, you can google a part store that sells them in your area, or ebay also has many
May 17, 2010 | Dell Latitude D810 PC Notebook
Very dark display screen almost black,dell latitude d810
Hi
fn + Up Arrow
fn + Right arrow
Feb 22, 2010 | Dell Latitude C610 Notebook
System won't start up.
OK, your system appears to be posting but you have a NO VIDEO issue. Most likely the issue is a backlight failure of the LCD screen. If available, you can connect an external monitor to the VGA port and press FN+F8 to toggle between the LCD and the External screen (Wait 15 seconds between toggles)
The components are fairly easy to replace and available on Ebay.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=latitude+d810+LCD&_sacat=See-All-Categories
Nov 21, 2009 | Dell Latitude D810 Notebook
Laptop screen colors are all muted.
Connect an external monitor to your laptop. If it displays beautiful colors that means you have a defective backlight/inverter/screen. Have it checked by a professional. It could be expensive to fix. You may think to buy another laptop.
Oct 06, 2009 | Dell Latitude C610 Notebook
Dell Latitude D810 Notebook Logo
Alun Cox
