Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung rf267aars icemaker stops making ice, icemaker makes clicking noise.
    Habit-Forming:
  • 76 Answers
Unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Posted on Jun 23, 2009
My ice maker makes a popping noise when it getting ready to dump the icecubes..pops ten times then deposit ice into ice bin. is this a problem that needs attention?
...known problem with the samsung icemakers. Need to order a new icemaker. The new icemaker should come with a new control board with upgraded firmware.
Sep 29, 2010 | Samsung RS2630SH Side by Side Refrigerator
My Kenmore refrigerator (596.52673200) is making a noise every 3 minutes or so for about 15 seconds. It seems like it is trying to fill the ice maker. There was ice in the little rubber tube leading to the...
Put the icemaker arm in the lock position to turn it off.
If it is the icemaker making the noise, the noise should stop.
If the noise stops,replace the icemaker.
If it does not stop,let us know.
Sep 22, 2010 | Refrigerators
Our GE side by side fridge isn't making ice. The arm in the ice maker starting clicking in the middle of the night and my husband just went into the freezer and held the arm up for a few seconds. The...
It sounds like you have a bad icemaker. Usually when the arm is clicking its the gears that are stripped out. Feel in the icemaker if theres cubes frozen in there then you know the icemaker is definitely bad. With the arm in the up position it will not make cubes at all that is the off position for the icemaker. Hope this helps _MJ_
Apr 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge makes clinking noise periodically throughout the day. It is getting worse and louder. It started after i put the ice cube maker back into action (i had it in the upright position to stop making...
If the noise is only heard when you activate the icemaker, then your problem is probably with the icemaker. Some icemakers make more noise than others. If it's unbearable, replace the icemaker.
Feb 19, 2010 | Whirlpool GB2SHDXTT 22.1 Cu. Ft. Gold...
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
We own a RF267AARS/XXA refrigerator. Ice maker works slow. Hardly ever makes a full tray of ice in 24 hrs. Then for no reason quits making ice for 2-3 days. I the pull the ice-tray out a couple of times...
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
Oct 29, 2008 | Refrigerators
Two issues
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Oct 17, 2008 | Samsung RF265AA Bottom Freezer French Door...
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
1,489 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
