Question about Cub Cadet Garden
Cub cadet runs fine while idling but cuts off soon after mowing starts
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Need to clean carb rewbuildit and that will takeof the problem
Posted on Dec 17, 2014
  • 11 Answers
SOURCE: cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Posted on Mar 15, 2009
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
SOURCE: I own a cub cadet LT1042. I started mowing tonight
Replace your drive belt
Posted on Jun 30, 2009
  • 85 Answers
SOURCE: cub cadet LT1045 died while mowing.wont start. its
Check & clean down to bare metal the battery connections, also check fuses
Posted on Aug 19, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
Cub Cadet HDS-2135 13B-214F100, runs great for 45 - 60 minutes then cuts out, only run on full choke, cannot mow but runs. Cools down works fine again
check the fuel filter and fuel line. it may need to be insulated to protect from heat. running on choke means it is starving for fuel . take the carburetor off and clean it real good. be sure the fuel lines are away from heat source.
Jun 09, 2016 | Cub Cadet Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
As soon as i engage for the mower the belt comes off
THERE IS A TENCHON POLY ON THE BAND SO JUST ULTER THAT
May 19, 2013 | Cub Cadet Garden
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
42 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
