Question about Husqvarna Garden
Husquvarna 350 chainsaw won't stay running
Start the saw , runs for a few seconds and stalls
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 250 Answers
There could be a couple of things wrong. Check fuel filter and fuel lines for integrity. Then check air filter. Replace sparkplug with proper resistor style plug. If the saw will still not run, check compression, should be between 120 - 145 lbs.
Still nothing, check to make sure ignition has good ground where it mounts on case.
Posted on Feb 03, 2016
  • 211 Answers
SOURCE: chainsaw cuts out a few seconds running
hi frado
check the fuel lines,make adjustment to the carb,set the T ,check the fuel filter.Inside the carb,at the fuel pump side there is a screen,carefully clean it.Hope theese help.
regards savumihai71
Posted on Dec 01, 2008
picatudo
  • 239 Answers
SOURCE: runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
Posted on Dec 31, 2008
#1 Taper
  • 1040 Answers
SOURCE: Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
Posted on Jun 10, 2009
  • 4088 Answers
SOURCE: husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Posted on Jul 14, 2010
gunzzzz
  • 391 Answers
SOURCE: my husqvarna 350 chainsaw starts but wont stay running for more than a few seconds
Eric:
Find the gas/air adjustment screws on the carb (next to the the throttle cam where the throttle cable attaches. Turn the screws in all the way... GENTLY... Those are needle valves, and too much torque on them will damage the needle valve seats. turn both of them out one and a quarter to one and a half turns. Start the saw, and adjust one or the other screw in or out until the saw runs properly. If there is a plastic stop installed on the screws, remove it first, and replace it after the saw is running properly. You have to be patient while tuning the carb as it may take a while. If you adjust too much and the saw refuses to start at all, start over with the 1-1/4 to 1-1/2 turns out on the screws.
Posted on Aug 19, 2012
350 husquvarna chainsaw don't have a primer bulb
350 saws did not come with primer bulbs.
Oct 09, 2016 | Husqvarna Garden
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
My husqvarna 350 chainsaw starts but wont stay running for more than a few seconds
Eric:
Aug 19, 2012 | Husqvarna Garden
Older (early80s) 80cc jonesred wont stay started, It runs for a few seconds after i pull the recoil and only with the choke open the it stalls out
Fuel starvation, replace the filter in the fuel tank, check the fuel hose up to the tank for signs of leaks or cracks, if no better it will need a carb service, and clean the internal carb filter, as it is an old saw new diaphrams will probably be required.
Oct 05, 2011 | Garden
Husky 51 runs for a few seconds dies than when i open gas cap and put it back on saw runs a few seconds than dies
Check the fuel filter for plugging. Check the fuel lines for decay or other damage. If the cap vent was stalling the machine, removing it should allow about a minute or so of running before it quit again. Hope this helps!
Dec 14, 2010 | Garden
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna 235e will not stay running
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Won't stay running
HI. I THINK IF YOU PUT A KIT IN THE CARB I THINK THAT WILL FIX THE PROBLEM. JIMBO
Sep 15, 2009 | Garden
Husqvarna chain saw starts and runs for a few minutes then shuts off.
sound like the ignition coil is bad.......they have had some issues with them.are you taking the saw to a husquvarna dealer or just taking it back to lowes.some times they don't send them to a husquvarna dealer....
Feb 19, 2009 | Garden
Runs for a few seconds then stops
Dec 30, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
27 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
