Question about DreamCatcher Interactive Enigma: Rising Tide - You Are In Command for Windows
Why won't enigma rising tide open in windows 8.1?
My enigma autoclave isn't starting. There is no error message on the screen. It just beeps 3 times and does nothing?
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
Nov 20, 2016 | Computers & Internet
Settler Rise of an empire on Windows 8
Settler Rise of an empire on Windows 8? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 001 170DTLA AH Proview 860 AB0 170DTLAQH Power Supply Backlight...
Jun 12, 2013 | Ubi Soft Entertainment The Settlers: Rise...
Charges related to Spy Hunter and Reg Hunter
Go Pc Pro Best Online Computer Tech Support Provider
Feb 20, 2013 | Computers & Internet
My cd code will not work keep getting an error message,
The code is called an activation key, and it is good for one computer install only. In order to get a valid code for this new computer you must contact the software makers support by email and and explain that your old computer crashed and you need a new activation key code for the replacement, they may provide one free of charge, but not all do, it is a good will type of situation.
Dec 20, 2011 | DreamCatcher Interactive Enigma: Rising...
My bio500ue enigma 500g acomdata hardrive, works just fine on my computer with windows vista, but my new computer with windows 7 doesn't recognize it and gives me messages saying it hasn't installed...
your windows 7 is trying to use the native driver for usb hard drive, but its having a hard time installing it so thats why you are getting it hasnt installed properly, you may want to install a driver specifically from your HDD manufacturer try to look for the driver on the website. you can also use the driver for vista on 7. hope that helps
Mar 23, 2011 | Acomdata BIO500UE Enigma Ruggedized with...
328xi Left rear window will not close. When you operate the switch window tries to rise maybe 1/8 inch and then returns to full open What do i do
sounds like the cables on the window regulator are streched or it could need the perimetre settings on the window reset this can only be done by a bmw dealer
Dec 25, 2009 | 2007 BMW 328xi Sports Wagon
DreamCatcher Interactive Enigma: Rising Tide - You Are In Command for Windows Logo
111 people viewed this question
Top DreamCatcher Interactive Video Game Consoles & Games Experts
Dominic
Dominic
ray gallant
Are you a DreamCatcher Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
