Gateway 340UI Overheat
Unit powers off after roughly 40 minutes of powered activation. Problem is CPU overheating; bottom of unit is extremely hot to the touch and experiments with elevating the unit off the surface of desk and positioning an external fan in front of primary exhaust vent. Please advise.
    Scholar:
  • 92 Answers
Well, I can tell you this. With most laptops the fans **** in air and blow it into some copper fins. These fins are very close together so dust and dirt clog the the air flow over the fins. Try this, get some canned air and go outside. Look for the copper fins (should be where hot air use to come out). Use the air to blow out the dust. Also blow air into the fans. Good luck.
Posted on Jun 23, 2009
Gateway gts5674
Desktop or Laptop computer ?
The high speed fan could be a dirty computer or thermel paste has dried causing you computer overheat.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hope this helps.
Nov 21, 2012 | Gateway (4000068) Motherboard
GLEQ21512ES1 overheating fast
Hello Anne Truhlar - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If the dryer continues to overheat then I suggest contacting a professional to accurately diagnose and repair the dryer. The unit could possibly have a defective control board, power supply (240V), heating element, sensor or high limit thermostat.
Sep 30, 2012 | Frigidaire GLEQ2152ES Electric Dryer
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Hi. I have a problem with my 42 inch plasma tv,when tv is turned on green L.E.D appears on bottom right and tv works as normal.After 40 minutes to an hour tv makes click sound and screen goes blank the...
Hello, A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage.
I hope that this help to rectify the fault of the projection TV....
May 12, 2011 | Televison & Video
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
May 30, 2010 | Krups FLF2 Cordless Electric Kettle
OVERHEAT PROBLEM HAS BEEN DISPLAYED ON THE SCREEN AND I WAS ORDERED TO SHUT DOWN THE UNIT
Its probably your CPU overheating.
Disconnect the power, remove the battery.
Try and take any plates off the bottom of your laptop.
and clean out any dust collected there with a bristle paint brush.
Make sure all vents are clear and try again.
May 03, 2010 | Toshiba Satellite A10-S403D PC Notebook
I have an MPC Clientpro 414, in 07 I replaced the power supply.
This is most likley a overheating problem. I work for a company who uses 2 of theese computers for each of our almost 600 stores. As one of the facility support guys, I have seen this time after time. What I do is to remove all the access panels from the back of the computer as well as the HDD and optical drive (they both should slide out easily after removing 1 screw each) and blow the entire thing out with a whole can of air. I also remove the HDD from it's sled and blow it off to keep it cool. Put everything back together and you will be good to go again, at least until the backlight inverter burns out. Good luck!
Mar 17, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
May 12, 2008 | Gateway FPD2275W LCD Monitor
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Feb 04, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Open Questions:
The smartest way to keep your business files secured on online cloud backup The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Aug 18, 2018 | The Computers & Internet
Computers & Internet Logo
404 people viewed this question
Alun Cox
David Payne
David Payne
