Question about Frontgate Retractable Hose Reel Post - Frontgate
Hose will not retract - Frontgate Retractable Hose Reel Post - Frontgate
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
Kitchen faucet hose will not retract on its own
Faucet hoses use gravity to pull them back down into position. You want to add some weight to the hose or clear the space underneath your sink. Usually a big heavy nut will do the job as well.
Feb 17, 2013 | Delta 24T2621-LS-R6 Single Control Mixing...
My Grohe kitchen pull out faucet will not retract
Normally, there is a weight on the hose (under your sink) that retracts the faucet line. Look under your sink and make sure that the weight is still attached and that there is nothing interfering with the hose moving.
Jun 03, 2011 | Grohe Plumbing
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
I have a Glacier Bay(Costco) kitchen faucet. The hose is counter-balanced with a weight that doesn't allow the hose to retract completely into the faucet, leaving about 2 inches to dangle out of the...
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
May 15, 2010 | Globe Union Glacier Bay 8 In Double Handle...
New brake shoes all around, but front passenger wheel still locking up and smoking
Most times your problem can be traced to a binding caliper piston or a brake hose that is internally deteriorated and holding pressure instead of permitting it to release. If the caliper slides are free and the piston can be easily retracted chances are it is the hose. If piston won't retract, check it again after removing it from the hose. If it retracts change the hose, if it's still tight, replace the caliper. Also possible that it's an abs problem, if so check that the trigger wheels on the axles are clean and the sensor wiring is intact and that they're working.
Nov 28, 2009 | 1997 Jeep Grand Cherokee
Telescope wont retract into hose
get a replacement hose witch is fairly hard to fit
Aug 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Jun 19, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
My grohe kitchen faucet hose won't retract
the first thing you need to check is the weight on the hose under your sink. if it is set too high or to low it doesnt allow the proper weight to pull the hose back into position. also check to see if the hose is twisted under your sink also. I hope these answers will help you out.
Apr 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Frontgate Retractable Hose Reel Post - Frontgate Logo
176 people viewed this question
Top Frontgate Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Frontgate Garden Expert? Answer questions, earn points and help others
