Question about Craftsman Garden
WHY WONT MY MOWER KEEP A CHARGE. I
I have a riding mower that the battery will not keep a charge. I have to stop and charge the battery every 45 minutes. what could the problem be???
3 Suggested Answers
  • 246 Answers
SOURCE: riding moweer wont charge the battery when mower
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
Why poulan pro riding mower wont charge
First check your battery, make sure the cells are good and no bad cells. If that is good then the issue is under the flywheel. There is a coil under your flywheel that serves as a generator. You can just purchase a 2 am charger with a breaker, that will kick out when battery is charged and hook that up after each use. If you jump a unit or charge a unit with more than 2 amps, you can burn the generator coil out under the flywheel. Also check the magnet under the flywheel. I have seen them come out.
Aug 24, 2014 | Poulan Garden
Why will MY MOWER WILL NOT KEEP A CHARGE.
dead battery, if you have a nicd or metal hydride you must recondition them , if you have a acid battery you must change them , the samme for litium
May 10, 2014 | Craftsman Garden
Needing to know how to keep the riding lawn mower running?
Can you tell us what the model of the engine is that is on that unit?
Aug 19, 2017 | Garden
Battery not charging
Looks like the battery is wasted. I'd have it replace it. A new battery should keep charged for longer period of time.
Jun 19, 2012 | John Deere Garden
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
Have a Yamaha YT3600 lawn tractor. The battery is good but mower will no recharge the battery. replaced battery and have the same problem. my knowledge of the electrical system on this lawn tractor is...
the starter puts out the amps to charge the battery, you have do an amperage check to find out what its puting
any good parts store will set you up with an inexpensive tester
Jul 23, 2011 | Garden
Battery will not charge
IS THE BATTERY GOOD,IF THE BATTERY IS BAD IT WONT CHARGE IT,IF ITS GOOD THERE SHOULD BE A 20 AMP FUSE FOR THE GHARGEING SYSTEM
Mar 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Battery won't keep a charge
hello,
How old is the mower? now and again these batteries can just die the easiest thing to do is get it load tested by a battery retailer annd they will be able to tell you if it has dropped a cell if it has it will not take a charge...
Dec 30, 2009 | Black & Decker 19" Electric Lawnhog...
Mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
May 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
