Question about Excalibur RD50 Turntable
How to take needle off rd50
Don't have the manual. All the record skipping not making contact with the needle maybe.
I bought a new turntable and it doesn't spin straight, causing the record to skip and bounce
Sounds like you have a warped platter. If you bought it new, return it and get a replacement. If you got it used, contact the manufacturer for a replacement part.
Jan 05, 2016 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
I have a Panasonic pll multiplex circuit and when I put a record on it skips a lot. I have another record player at my other house and it has an adjustable weight on it, and I am thinking that that's...
Most likely needs a new needle. Try needlelady.com or needledoctor.com Modern record players usually track at 2 to 4 grams of pressure. Thats about as much as a penny weighs maybe. Putting more pressure on it, will only cause it to destroy your records or sound bad. Weight adjustment is usually a very fine spring or counterweight that adjusts on the tonearm. Linear units use optical sensors to keep the tonearm aligned, but use traditional counterweights to control force. You need a gram scale made for phonos to properly adjust it. Radioshack USED to sell them 30 years ago, but most times you can just use a guess if the needle only slightly deflects when placed onm the record your usually good. If it's simply jumping and sliding across the record then the needle is shot. Even diamonds don't last forever,. as they are synthetically produced.
Jun 19, 2011 | Audio Players & Recorders
Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
May 03, 2010 | Technics SL-1200MK2 Turntable
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
51 people viewed this question
Top Excalibur Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Excalibur Audio Player and Recorder Expert? Answer questions, earn points and help others
