Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Water leak fridge
Water collecting in bottom drawer area and overflowing onto floor. Plastic collection tray at back of fridge is dry leading me to believe that drain tube is blocked, backing up and overflowing into bottom drawer area. How to unblock any obstructions?
    Habit-Forming:
    Scholar:
  • 48 Answers
The condensation in a fridge is generally routed to a small drain hole at the bottom at the back. The water drained off here normally drips onto the compressor unit (the big black ball thing at the back) where it gets evaporated off, due to the heat the compressor generates. Before taking steps to unblock the drain, you might consider defrosting the fridge first. When unblocking the drain, do not use wire, unless the fridge is switched off and unplugged, you never know where that wire will end up (electrocution risk!). There are two good ideas for clearing the blockage. The best way off clearing the tube is with compressed air, often difficult to get in your kitchen, but don't despair, there could be two solutions in your garden shed. If you have a Weed-killer Spray that uses a pump to pressurise the spray pot, you could use that to clear the blockage (with a bit of ingenuity). Clean the spray thoroughly first, you don't want to poison anything in the fridge, and use the spray with no liquid in it. You can take off the spray nozzle and use the pipe in the hole. If you need to manually unblock the tube, you could use a hard nylon "cord" that is used in a garden strimmer. Pocking that down the hole and into the pipe should do the trick. It's flexible enough to get around the corners in the pipe and when it emerges at the other end it won't electrocute you if it touches a live connection. Lastly, having removed the blockage, put a very tiny bit of "plughole unblocker" fluid in the pipe, that will clean out all the other residue not pushed out with the cord. Good Luck!
Posted on May 11, 2014
  • 4 Answers
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Posted on Nov 17, 2008
SOURCE: F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Posted on Oct 30, 2009
SOURCE: my 5 year old fridge
Don't ask these guys. The problem is that the drain tube is plugged. This is the same issue I had and got no help. Go to the back of your fridge and dissconnect the black tube. That tube is probably plugged. Clean it out and reattach and your good to go. It took me 4 hrs using these guys and this is a 1/2 hr job. Good luck.
Posted on Aug 30, 2010
dcramer531
  • 1654 Answers
SOURCE: We have bottom freezer model
it may be because the hole under the defrost coil is blocked with ice. There is an easy way to eliminate this problem in many refrigerators. Follow these simple steps to stop this problem from happening.
  1. Empty out freezer compartment and open up access to evaporator coils and defrost coil.
  2. Use hair dryer or heat gun to melt any ice that is around coils and in hole to bottom of refrigerator that normally drains the water out of the compartment. Towels or a shop vac may be needed to clean up water as the ice melts.
  3. Blow through hole to make sure that it is free of debris and ice.
  4. Use a piece of bare uninsulated 14 Ga. Copper or Aluminum wire. Place one end of the wire into the hole as far as possible and then cut off enough to wrap a turn or two around the defrost coil.
Now when the freezer goes into it?s defrost cycle a small amount of heat will be transferred by the wire down the hole to make sure that it remains ice free. This will solve your drainage problems with your freezer defrosting and water running into the refrigerator compartment
Posted on Jan 26, 2011
heatman101
  • 43501 Answers
SOURCE: Our 12 year old fisher
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
Water collecting inside refrigerator
At the back is a little channel with a hole in that drains to the outside of the fridge. Remove the drawers and shelf and blow through the hole with a drinking straw.
Jun 13, 2012 | General Electric Refrigerators
Fridge freezer is 6 years old - water is collecting at the "drain area" (not sure this is what it is?) and not draining so that there is a collection of water which is then overspilling and...
I'm presuming that this is a self defrosting fridge. When it defrosts, the water runs down the back of the fridge inside and collects in a gully, just above the vegetable drawers (If you have them), it runs through a hole in the centre of the gully, down a pipe to a plate which is positioned above the compressor at the back. The compressor gets warm and the water evaporates.
The hole in the gully is probably blocked with debris or mould, as a result, the water overflows onto and into the drawers. MOST fridges have a dip stick like device in the hole, which you can use to jiggle up and down and clear any blockage. If you don't have such a dipstick, a soft wire or bit of plastic tie will do to clear the pipe. Worst case, you may have to pull the fridge away from the wall and check at the back. The compressor, plate and drain hose (about the thickness of a pencil and usually clear plastic) should be clearly visible. Sometimes, the hose gets dislodged so it doesn't drip onto the plate, sometimes the blockage will be at the end of the hose that runs out onto the plate, rather than inside the fridge. You can try blowing into the hose, which should be free and clear to blow through, or pushing a soft flexible wire down the entire length of the pipe to clear any blockages in places you can't see.
Jul 27, 2011 | Refrigerators
Water collecting at bottom of refrigerator under the two drawers
You probably have a self defrosting fridge. When it defrosts, the water runs down the back of the fridge inside and collects in a gully, just above the drawers, it runs through a hole in the centre of the gully, down a pipe to a plate which is positioned above the compressor at the back. The compressor gets warm ant the water evaporates.
The hole in the gully is probably blocked with debris or mould, as a result, the water overflows onto and into the drawers. MOST fridges have a dip stick like device in the hole, which you can use to jiggle up and down and clear any blockage. If you don;t have such a dipstick, a soft wire or bit of plastic tie will do to clear the pipe. Job done.
Jul 05, 2011 | Whirlpool Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
How do I empty the tray when full in the back of my model 253.74810400 fridg? Also leaking water from somewhere onto the floor.
the water on the floor will be from the overflowing reservoir at the back of the fridge. i would suggest buying a syringe ith at least 20ml capacity usually you can get them from hardwear shops, and use it to emty the tray at the back. Make sure that the pipe leading from the drainage port to the reservoir (drainage port is located inside inside of the fridge at the back) is sitting inside the collection reservoir and not hanging over the side causing the puddle.
Aug 08, 2009 | Kenmore Refrigerators
Freezer leaking on Kitchen Floor
the pipe which is located at the back of the fridge/ freezer may be blocked or hanging outside of the designated collection chamber designed for this purpose. Unplug from the mains and pull the appliance away from the wall so you can see and get to the back of it. At the back of it you will see a pipe coming out from the bottom of the cooling fins and will go down and the end of it will be sitting inside a shallow plastic collection unit - not covered but open. Itusually is sitting on top of the condenser unit. (this is a large sealed metal structure whic has pipes coming out of it and is the largest item in that area at the back bottom end of appliance). If there is some liquid in it then either move the pipe end into the dry area or emty it out. Sometimes there isnt a collection chamber but the pipe just drips onto the condenser and evaporates - usually on self defrosting certain brand named products but dont know much about that. Use a pipe cleaner to clear out the pipes from inside the fridge out toward the back using that pipe. the drainage hole is inside the fridge at the back and may have some sort of cover or plug in it. remove that and clean it and use the wire or pipe cleaner to shove doen the hold and clear the entrance and exit. Test pipe functionability by pouring a small ammount of water down the drain hole and see it coming out of the back via pipe. If still leaking make sure the vent areas in the back of fridge and freezr are not covered expecially in the self defrosting models. basically dont overload the fridge or freezer coz this causes blocked vents, difficulty derfosting on self defrosters, water builds up and gets out via the tube as it should, but more water than can be evaporated will cause puddles on the floor
Jul 03, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
136 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
