Question about Kia 2008 Sorento LX
I have codes p0700 and p0768 what are they? - Kia 2008 Sorento LX
I get code p0700 on 2004 dodge ram 1500 4.7 lt.
transmission system malfunction can be a few things the following links give some examples of different problems associated with p0700 code but more than likely if their is a noticeable problem than may have to have it diagnosed by a transmission shop
P0700 Transmission Control System Malfunction P0700 Dogge Ram Yahoo Video Search Results 2005 Dodge Ram 1500 transmission codes p0700 p0841 Transmission Automatic...
Aug 05, 2016 | 2004 Dodge Ram 1500
Error codes po700 and po768
po768 is shift solenoid "d" control wire open or shorted. p0700 is a generic code that the transmission send to the ecm and is not relivant at all. to fix the first code p0768 you will need to know if the wire is broken or damaged from the solenoid to the computer the solenoid is inside the transmission and the computer is under the dash board infront of the steering wheel. here is the procedure you need to take to diagnose it.
Dec 15, 2014 | 2007 Subaru B9 Tribeca
I have a 2007 b9 tribeca with error codes po700 and po768 what do these mean
Subaru P0700 Transmission Control System Malfunction
Subaru P0768 Shift Solenoid D Electrical
What do the codes P1684 and P0700 mean?
Hi Rich Stuck,P0700 means Transmission Control System (MIL Request),P1684 means Battery Disconnected within last 50 starts.More read Diagnostic Trouble Code Table ,hope it can help you.
Dec 08, 2012 | 2002 Chrysler PT Cruiser
What code p0768 in the isuzu d max 2008 is
Diagnostic Test Code (DTC) P0768 is defined by SAE J2012 as "Shift Solenoid "D" Electrical".
This means that the shift solenoid (solenoid "D") inside your transmission has an electrical fault. This could be due to an electrical malfunction in the solenoid itself, or the wiring that connects it to the transmission contol unit.
Jun 15, 2012 | Cars & Trucks
P0700
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 29, 2012 | 2008 Saturn VUE
Code p0700 ford f450
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 03, 2012 | Johnny Lightning Classic Ford F450 Clark's...
What do i need to replace to fix error code p0700 on a 2002 dodge intrepid
(DTC) CODE # P0700....Transmission Control System (MIL Request) Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it.
I hope this helps....let me know if I can assist further !!
Feb 21, 2011 | 2002 Dodge Intrepid
Car does not run ,I check the code ,it is P0700
Because it is not starting, you should replace the Crankshaft sensor (above the oil filter, back of the engine)-it will cause a P0700-I have a 99 SL2, 178,000 miles
Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it. The dealer probably saw the code P0700 and went to the TCM and pulled out the code stored there telling them the Transmission Solenoid Assembly (TSA) is bad. This is a good example of understanding what the codes actually mean. If the manual you looked at said the TCM is bad and to replace the TCM when you see a P0700, then it is wrong.
Jan 24, 2011 | Saturn Ion Cars & Trucks
Kia 2008 Sorento LX Logo
60 people viewed this question
Top Kia Heating & Cooling Experts
terry stevens
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Kia Heating and Cooling Expert? Answer questions, earn points and help others
