Question about Canon ImageCLASS D1120 All-In-One Laser Printer
How to remove fuser unit
Have removed the document feeder unit. Have full access to fuser however not sure which gears to remove from end of fuser
5 Suggested Answers
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
redzventures
  • 149 Answers
SOURCE: how do i remove the fuser unit?
Firstly, you have to take off the left hand door by opening the lower door and removing the metal wire retainer that is hooked over the machine chassis. Once the door is off, you will see a black plastic cover just above where you removed the retainer from. One screw removes that to expose the connectors for the fuser. There is a black plastic guide that runs the length of the fuserone screw removes that - be sure to note the way this guide fits under the roller shaft for reassembly. Once this is removed you will see the two screws that hold in the fuser remove them and the fuser slides out at an angle, i think you pull towards you first, the side towards the front of the machine. If it feels stiff then you've got the green latch in the front of the machine in the wrong position, turn it the other way. You need the front door open for all of this. Good luck.
Posted on Jul 09, 2009
  • 385 Answers
SOURCE: printing a black solid line down centre of page
lift up the document feeder and clean the thin glass strip on the left side!
Posted on Mar 31, 2010
nonontech
  • 4737 Answers
SOURCE: Scan and fax fail when
Have you tried cleaning the adf passage and other passages?
Before you start with the instructions below, remove all the cartridges, turn off the machine, remove papers, unplug the power cord and the usb cable (if any).
First of all, lift up the (auto document feeder) adf towards outside (as shown below):
Check for any foreign particles like broken pieces of paper, etc.. If possible, clean the gears and other components.
Also, open lift-up the scanning unit, clean the passage as shown below:
Also pull out the Feeder (not the Auto Document Feeder/ADF) and clean everything properly.
Now reconnect or reinstall all the remove components, push in a paper (thicker paper like chart paper or photo paper) through the feeder passages, both ADF and front. Do this forcefully and now power on the Machine.
If there's no internal mechanism faulty or damaged components, this will definitely help you fix your issue.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 05, 2010
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
Tip
ERROR codes Canon 4835
Canon 4835 E000 Low fuser temperature E001 High fuser temperature E002 Low fuser temperature E003 Low fuser temperature E010 Drive E030 Counter E080 Color change board problems E081 Color horizontal motor problem E082 Color horizontal motor problem E083 Color problem in vertical direction E084 Color problem in vertical direction E085 Color problem in vertical direction E086 Color unit claw release problem E089 Color change incomplete E100 Laser problem E110 Laser motor problem E140 Laser unit E203 Scan drive problem E210 Lens not home or won't leave home E240 DC controller E401 Document feeder pick up motor E402 Document feeder belt motor E403 RADF feed motor E404 Document feeder motor E411 Document feeder sensor E500 Sorter to DC control interface problem E510 Stapler/sorter motor E530 Stapler swing motor E531 Stapler swing motor E540 Sorter bin motor E541 Sorter bin motor E710 DC controller
on Jan 19, 2010 | Office Equipment & Supplies
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Fuser error
Your machine is in need of a new fuser unit. HP LaserJet 2400 Maintenance Kit Installation - Fuser (Part 1 of 2) Installing the fuser. Turn the power off and unplug the printer. Wait 20 minutes for the printer to cool.
Open the back door of the printer, using enough force that the door opens completely and the hinge locks disengage, as shown below.
2400_openbackdoor.jpg Remove the 2 screws circled in red below.
2400_removebackscrews.jpg Close the back door, and then flip the printer so that it rests on its face. 2400_closebackdoor.jpg 2400_flipprinter.jpg
Next swing open the paper guard which shields the back of Tray 2 when it is installed.
Looking inside the Tray 2 cavity, use a flatblade screwdriver to release the two tabs--one on each side of the rear cover.
Next remove the rear cover from the printer by pulling down and away.
Fuser Installation Continued . . .
Pry the grey DIMM cover loose and remove it.
Use a small flatblade screwdriver to disengage the tab on the connector shown below and unplug the connector.
Next (on the right hand side) remove the small black plastic cover, located near the green fuser gear, which hides the other fuser wires.
Then unplug the two connectors shown below and free the yellow/white wire from its guide clasp.
Now remove the four screws holding the fuser in place (shown below).
Now remove the black plastic piece shown below, the duplexer inlet guide. Gently pry the tabs on both ends loose and slide/rotate the guide back towards the fuser to release it.
Now you can remove the fuser, just pull it straight out towards you. Don't install the new fuser until you've replaced the main motor gear, as shown below.
Replacing Fuser Drive Gear
With the fuser removed, look into the printer and locate the main fuser drive gear on the left side of the fuser cavity (gear circled in red below).
Use a flathead screwdriver to pry the gear's release tab and remove the gear by sliding it off its metal bar.
Slide the new gear onto the metal bar--make sure the gear's release tab faces outwards so it will be accessible again--and lock the gear firmly in place.
Now repeat the fuser removal process backwards as you install the New Fuser:
Insert the new fuser and replace the four fuser screws. Replace the black plastic duplexer inlet guide, making sure both tabs click in place. Re-plug the single connector on the left side, and the two connectors on the right side. Replace the wire cover on the right side. Reinstall the DIMM cover. Finally, replace the back cover with its screws.
This is a difficult installation which should be done by a technician. Good luck with it !
Sep 23, 2011 | HP LaserJet 2420 Printer
Taking the whole fax machine apart... how does one replace the fuser?? Panafax 8000
It is as hard as it looks
You must have a LONG #1 phillips screwdriver
Remove OP panel and unplug
Remove ALL Plastic Covers
Remove document feeder
Remove metal circuit board cover on left side
Remove Toner Cart
Remove eject assembly
Remove 4 fuser screws and wiggle fuser out
Mar 24, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
Broken fuser gear
To access wires/connectors
remove back cover 4 screws
open and remove right door 2 screws on back frame one with small spring attached
remove fuser unit with 2 screws unplug 3 connectors
on back of copier.
remove one screw on wire end of fuser/cut ty wrap with wire cutters be careful not to cut wires!!
pull off cover
remove heat lamp by pulling on copper end piece
slide lamp up and out
remve small c shaped retainer ring from end of roll with 2 small flatblade screwdrivers
take off old gear and install new one-lubricate bushings with a few drops of fuser oil on both ends
re-assemble in reverse order.
any questions just ask!!
Jul 25, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
XD100 Workcenter Copy quality
If its is a fine line. Looking like a pencil line. See if it is there when you run it off the glass or through the document feeder. If it is only there when it is run throught the document feeder, the small strip of glass under teh document feeder had some contamination on it.
You may have something on the optics. Mirror or lamp carriages. You would want to clean those. The Drum cartridge could be bad. Take the drum out and see if it's on the drum.
The transfer wire on the lower part of the right hand door, just above the white rollers and may need cleaned.
Last and the least likely would be the fuser roller. That is the heated area just before exit area of the machine, You can look in there with a flash light and see if any of that roller is worn.
In order, I would think . 1, Drum, 2 Optiscs, 3. Fuser,4 Transfer corotron wire on the right door.
Mar 17, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper jams
Hi, 2 things to check. First when you lift and close the toner door, do the exit rollers on top of the printer turn for a couple of seconds. You just put your fingers where the paper comes out and see if they turn. If they do not then you may have a fuser or coupling gear isse. The other thing is to try and feed the paper from the manual feeder and see if it goes thur. If it does you have a sensor issue on the paper input unit and a sensor board will have to be replaced. If the exit rollers are not turning and the paper does not make it into the fuser, I would suspect one of the gears on the fuser has failed. Remove the fuser and inspect the gears and I am sure you will find the problem. Good Luck
Sep 04, 2007 | Dell 3000cn Laser Printer
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
43 people viewed this question
old marine
old marine
