Question about LG DX130 DLP Projector
LG DX130 DLP Projector - LG DX130 DLP Projector
HOW CAN I SET MY IMAGE VIEW AT ANGLES LIKE 180 DEGREES
http://www.lg.com/us/support-product/lg-PH300W#manuals The manual only shows distance to screen. There is no viewing angle adjustments.
May 23, 2016 | LG DX130 DLP Projector
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
LG DLP projector fan lock problem
hi, i have fan locked problem on lg projector.
Apr 23, 2012 | Optoma HD65 DLP Projector
Dlp projection, keeps switching to standby, also sometimes will start up and the picture goes blank but the sound remains
The lamp may be out. Projectors need high voltage/wattage lamps. They tend to only last 2000 hours or so, which is about a year or two with normal use.
Feb 04, 2010 | LG DLP Projector 1400Lum RD-JT30...
My lg dlp is blowing fuses as fast as i can replace them. what could cause this?
chances are there is a short on the power supply board. at this point you may need to replace it.
Dec 11, 2009 | LG DLP Projector 1400Lum RD-JT30...
Lg 50'' dlp tv
hi my is the same do you have a solution yet?
Feb 26, 2008 | LG DLP Projector 1400Lum RD-JT30...
Purple band on tv dlp LG
Hi there
This is definitelly not your bulb.
Check if there is any damage to the colourdrum , if not then this is a faulty Mainboard.
Must warn you that LG's Mainboards are very expensive.
Feb 04, 2008 | LG DLP Projector 1400Lum RD-JT30...
Lg 44" dlp tv
Punch yourself in the face REALLY hard and then throw the TV out the window and buy a 60" Plasma or a 52" LCD
Jun 29, 2007 | LG DLP Projector 1400Lum RD-JT30...
LG DX130 DLP Projector Logo
35 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
scj103
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
