Question about Cooktops
Jenn-Air cooktop Manual please!
I need a manual for a 1995/1996? JennAir cooktop. Model# C206W-C. Where can I go to download a PDF or equivalent. www.jennair.com had nothing online. B
textonor
  • 130 Answers
SOURCE: Jennair gas cooktop
Sounds like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Personally I just advise pulling the plug and wait. This is a common issue with gas cooktops and can also happen with liberal use of cleaning products sprayed in the know area.
Posted on Jan 06, 2008
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
  • 161 Answers
SOURCE: JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Posted on Jul 01, 2008
Maytag317
  • 1136 Answers
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
Posted on May 24, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: How does one replace the
Sorry to read about your problem, I hope this helps you out.
yes needs special tool
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
How do I remove my electric cooktop...the conduit enter thru an L connector into the cooktop and prevents it from being lifted out...I cannot figure out how to get under the control knobs to access the...
On link below is a install manual It might not be yours but they are all pretty much the same. It will tell you how to install. You just do the reverse to remove.
Also you do not un wire the cooktop from the cooktop but from the junction box in the wall. Please make sure the breaker is turned off before you un-wire it.
http://www.jennair.com/assets/product/JEI0430ADS_Installation%20Instruction_EN.pdf
Apr 17, 2010 | Jenn-Air Cooktops
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Jenn-Air JED8430 Electric Cooktop
I can't find my owner's manual &want to use the self clean option
OK, here's the manual for your Jenn-Air CCE3401 cooktop in a pdf format that you can download and print, for free!
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20CCE3401B.pdf
IF this isn't your cooktop, as that's the model number you entered on this site, requesting help, go to the following link and enter in your model number to get the correct manual for your particular Jenn Air appliance:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Aug 28, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air JGD8345 Gas Cooktop. What are the ducting instructions?
go to :
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JGD834&siteCd=JA_EN_US#installation_instructions
and pick your installation guide from jennair directly...
Good luck
May 09, 2009 | Jenn-Air JGD8345 Gas Cooktop
Jenn-Air CCE3401 COOK TOP
Hello
I have both the manual and the intalation Instructions on PDF file.
Contact me and I will gladly email them to you.
Hope this will help you.
Eddie Rentas
Tupper Lake NY
Jul 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
80 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
