Question about RCA F27442 27" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
The RCA F27442 27" worked well until the day before yesterday. The upper half screen seems to be compressed to the middle and shows stripped image, but the other half screen works still good. That is, there is about an inch bright band in the middle (horizontal), and compressed image can be seen there. On the upper-half screen, there are stripped and the image seems to be extended. Is there any one can advise how to repair it?
    Problem Solver:
  • 11 Answers
Check for bad c14505 220mf.
or u14501 vertical output ic.
Posted on Jan 08, 2008
How do I check led strips on my rca flat screen tv? and/or how do i replace the led strips?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 18, 2015 | RCA Televison & Video
Good day!!!I i had problems with the fl 231 fuse on my RCA D52W23
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 14, 2009 | RCA R52WH73 Projection Television
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Green half moon at bottom of screen, then no picture or sound
likely a convergence problem which has gotten worse
May 14, 2012 | Hitachi Televison & Video
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
My RCA F36648 36" TV has only the bottom half of my picture working. The top half has horizontal lines that distorte the picture. It looks like when you pull a rake through the sand the lines that are left...
You have vertical output problems.There is distortion at the top because of a faulty vert. output i.c. or a faulty electrolytic capacitor.It's possible there may be a problem at your yoke also.It needs a professional repair.
Sep 29, 2009 | RCA F36648 36" TV
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
Apr 03, 2008 | RCA Scenium PHD50300 50 in. Plasma...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
RCA F27442 27" TV Logo
412 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
