Question about Whitehaus WHMFL3351-EB One Piece Dual Flush Eco-friendly Toilet
Where do I purchase a replacement toilet seat
Where is the serial number - toilet is 25 yrs old and need a new toilet seat.
Typically there is no serial number associated with a toilet seat. The seat will either be a round front or an elongated seat. Just make sure the shape is the same when purchasing the replacement seat.
Jan 20, 2015 | Porcher Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Replacing Sanicompact toilet seat
I have asked around they take a normal seat on most us models
Feb 03, 2009 | Saniflo 005 Toilet Tank White
How do you replace the seat on a kohler lowboy?
There are two bolts that are under cover at the back of the seat. feel underneath for the nuts-pop the caps on top w/ a screwdriver. make sure you purchase the correct profile seat Elongated or standard..
Jan 20, 2009 | Kohler - Toilet Seat - Moondance -...
Whitehaus WHMFL3351-EB One Piece Dual Flush Eco-friendly Toilet Logo
Top Whitehaus Home Experts
Donni Steen
Tom Chichester
Are you a Whitehaus Home Expert? Answer questions, earn points and help others
