Question about Amana ABB1927DE Bottom Freezer Refrigerator
I have a ARB2205CS that is 6.5 yrs old. It stopped
I have an Amana ARB2205CS that is 6.5 yrs old. It stopped cooling/freezing and the relay clicks on/off every 2.5 min with a 10 sec buzz between clicks. Replaced the overload relay, plugged in unit and it started cooling just fine. A couple hours later it started doing the buzz/click cycle again and the freezer warmed up again. Obviously teh relay was not the problem. Is this a faulty defrost timer that interferes with the cooling cycle once the first defrost cycle is initiated?
  • 7 more comments
  • bhasell Jun 23, 2009
    could a faulty capacitor (plugged into the relay) also create the buzz click cycle (and no cooling)? I'm currently using a new relay with the original capacitor and have the same symptoms.
  • bhasell Jun 25, 2009
    I was able to get a capacitor shipped in and that fixed the problem. No more click buzz, compressor is warm and freezer temp is dropping rapidly. For future reference, this Amana model relay and capacitor components are sold separately, not as an assembly. There appears to be a shortage of capacitors relative to relays which may suggest it is the more common component failure.
    Thanks for the help.
    oops, spoke too soon. the compressor started and freezer chilled from +20 C to -10 C in about 50 minutes at which point compressor stopped (normal I assume). I put shelving and a few ice packs in the freezer, lowered the temperature control and it started the click buzz cycle again. After an hour the freezer is back up to +10 C.
    At this point i assume nothing was wrong with original relay or capacitor. Could this be a thermostat problem? Does pulling and reinserting the capacitor cause some sort of reset condition? Witchcraft?
    I also should mention, as it goes through its click buzz cycle the compressor is hot and the condensor fan runs continuously. I assume the compressor is starting but then gets deactivated for some reason.
    My new theory (after finding a circuit diagram). A faulty freezer temperature control switch successfully turns on the compressor and fans (which initially cools the freezer) but does not shut down the compressor once the set temperature is reached. The compressor overworks and is shut down by the overload circuit. The temp control switch continues to try and restart the compressor which is quickly shut down by the overload. Fans run, compressor remain hot, freezer stops cooling. Does that make sense?
  • bhasell Jun 26, 2009
    Replaced freezer control and no joy... same symptoms :(
    Did discover new info: if I turn freezer control off, unplug fridge, wait 20 min, plug fridge back in then turn freezer on it does a normal cooling cycle until it gets around -14 C. If I shut down or start in a different sequence (e.g. just unplug, wait then plug in) the click buzz cycle begins immediately (i.e. no cooling). I'm baffled. Thinking of changing the dilithium crystals at this point.
  • bhasell Jun 29, 2009
    All peripherals components (fans, lights, door switches, door seals etc.) are working fine and I can't find any signs of leaks anywhere. Would a loss of gas pressure in the compressor system cause my problem (i.e. cools down once then goes into a click buzz cycle with gradual warming back to room temperature).
  • bhasell Jul 01, 2009
    For those following this thread, the general consensus is that the compressor is in the process of going bad. I had replaced key electronic components (relay, overload,capacitor, freezer control) and have the same symptom -- the compressor will start when it's cold but won't restart after it does one cooling cycle and is hot. I had assumed that the compressor fails or works but a local tech told me today that they can degrade and work sporadically until they completely die. He said replace compressor or get a new fridge, which seem to have 1 year warranties these days (my original Amana warranty was 5 yrs?). Replace compressor $700, new equivalent fridge $1700 -- what to do, what to do?
  • bhasell Jul 03, 2009
    The compressor has been replaced and fridge is running fine. The tech said that the compressors used in the 2002 vintage Amanas (pre-Whirlpool) are not very good (he has replaced many of them). The replacement compressor model is made by Whirlpool and has a very good track record. btw, the new compressor comes with new a relay/overload and capacitor, keep the ones off your old compressor for spare parts.
  • 46 Answers
Also does it have condencer fan on the comp is this working ?if not comp is over heating it needs that fan
Posted on Jun 26, 2009
    President:
  • 744 Answers
No, the relay was what caused the buzz click but i think a bad compressor could be responsible for blowing the relays out. If you had a bad defrost timer that was stuck in defrost thus compressor not running you would not get the buzz click..your comressor would also be cold.
Posted on Jun 23, 2009
  • 3 more comments
  • Mike Price
    Mike Price Jun 23, 2009
    According to the manufacturer you should change the whole assembly...if this does not work it's going to be your compressor im afraid.
  • Mike Price
    Mike Price Jun 25, 2009
    I'm glad to have assisted. Yes I knew the the relay and capasitor where sold seperatly as most are with a few exceptions...generally when i am on a service call i will replace both items...
    But hey it's fixed now that's the main thing...Have a good weekend :)
  • Mike Price
    Yes it does make sence, typically when cold control goes bad it has the effect of making the fridge run non stop. However in 20 years i have never seen a cold control effect the compressor..maybe because i normally get a call strait away.
  • Mike Price
    Mike Price Jun 26, 2009
    Just a clarification...I have never seen a cold control affect the compressor in this way.
  • Mike Price
    Mike Price Jun 29, 2009
    Hi, if after changing the relay,overload and control board you are still getting the buzz click your compressor is bad...In 20 years i have never found it to be any other problem upon replacing the relay and overload.
    Problem Solver:
  • 10 Answers
Yes your compressor is coming to a stop. There was a 5yr warranty I am sure but if it's 6.5yrs now it's still beyond coverage. I would call some authorized companies familiar with these models who replace the compressors. Not all companies do. Shop around for the best price. I am sure you can do better than $700. I can usually compete that job in 1.5hrs. And the replacement is a great compressor.
Posted on Jul 01, 2009
So bhasell, I'm unsure from these posts whether you ended up solving your problem. I am having exactly the same one (on a uints that just 3 years old) so I'd be very interested if you've solved it. My repair guy is talking about replacing the compressor, but it still seems to me that it has to do with the electronics that control the compressor (as the latter works sporatically).
My refrig just stopped cooling/freezing. 6/7 yr old side by side Amana asd262rhrw. the motor has been louder lately
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Refrigerators
The temp is barely cooling. The freezer side is cool but not freezing anything. The fridge is 11 yrs old. Is this something I can fix myself?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 24, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
Power on but not cooling
mostly either compressor or relay is bad. replace relay and see if it works, since that is cheaper part..
Jan 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Buzzing intermittent
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
769 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
